I am going to be installing HS in the private school my boys attend. The initial purpose is to be able to use HSPhone with the phone system. The phone system is a Panasonic KD1232 pbx system I installed last year. We want to be able to setup HSPhone w/ a w2c or w2c lite as one of the extensions, and use HSPhone software in order to utilize the phone system as a sort of bell system for the classrooms.
For instance, there would be events set up to have HSPhone dial ext *** (various paging groups) to page over all the extensions. HS would then play a .wav file (tone) and hang up. This would be set on a normal schedule. We would also have events set up to change from a normal schedule to a 2hr early release, late start, assembly, etc.
So, the main question is whether or not the W2c lite will allow for dialing an extension on the pbx and playing a wav file.
I'd also be interested in eventually using HSPhone as an auto-attendant which can allow a caller to press certain numbers for extensions, voicemail boxes, recorded messages (ie, late start info) and so on.
Ian
Ian
