arghhh been beating my head against this silly lock trying to include it to my zwave network. Using a fairly new HS Smartstick. I've tried sitting the lock right next to the smartstick, removing, re-adding, etc. Always the same messages. Any ideas?
Jul-13 09:16:23 Z-Wave Node: 6 Supports Class(es): APPLICATION_STATUS, MANUFACTURER_SPECIFIC_V2, FIRMWARE_UPDATE_MD_V2, SECURITY, VERSION_V2
Jul-13 09:16:00 Z-Wave Warning If this is an import, you may need to remove and add the device as some devices cannot be added with an import.
Jul-13 09:16:00 Z-Wave Warning Failed to get a SECURITY SCHEME or verify the key from node 6. Device may not be added properly to HomeSeer.
Jul-13 09:16:00 Z-Wave Error Z-Wave was unable to negotiate a compatible security scheme with node 6
Jul-13 09:15:49 Z-Wave Adding using S0 Security, Negotiating or Verifying SECURITY SCHEME for node 6
