I just found this while messing around with some EasyTrigger Device Groups and I verified outside of EasyTrigger as well.
Setup:
Windows 10 Pro
deConz 2.05.20
ConBee stick
HS3 .449
Lights: Osram/Sylvania Color LEDVANCE A19
Scenario:
functions from main interface work fine. In events if I set the event to on/off things work. If I set to a percentage in the drop down the lights do not turn on.
Found this when setting an EasyTrigger group to 100 and nothing happened. I started checking and found that the same event works when set to turn the device on but not to a value.
Setup:
Windows 10 Pro
deConz 2.05.20
ConBee stick
HS3 .449
Scenario:
