Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Eric Fetty Plug-Ins > RadioThermostat Plug-in (3P)
RadioThermostat Plug-in (3P) Discussion of RadioThermostat plug-in
  #21
Old December 3rd, 2015, 07:53 PM
dovla dovla is offline
Viewer
Quote:
Originally Posted by kingfetty View Post
This supports the CT-80 as long as it's using the Wifi U-SNAP module and not the Z-Wave. It currently doesn't have the Humidity and Data Areas as functionalities, but I do plan on adding it in a future release.
Any news on the humidity? Thanks
Nov-29 11:21:46   Plug-In    Interface RadioThermostat is running as a trial, 15 days remaining.
Nov-29 11:21:39   Plug-In    Found plug-in: RadioThermostat, version: 1.0.15128.9
  #22
Old December 10th, 2015, 09:38 AM
Richel Richel is online now
Seer Master
Quote:
Originally Posted by douggle View Post
Error adding thermostat with IP: 192.168.100.239
New installation and I have the same issue:
"Error adding thermostat with IP: 192.168.0.60"
I am using Version 1.0.15128.9 of plugin and HS3 Pro Edition 3.0.0.208 with Windows 10.
Elliott
  #23
Old December 11th, 2015, 07:53 AM
joey52685 joey52685 is offline
Seer Deluxe
Elliott
You need to create a config file as detailed in this thread: http://board.homeseer.com/showthread.php?t=174508
  #24
Old December 11th, 2015, 12:30 PM
Seer Master
Quote:
Thanks. That worked.
Elliott
  #25
Old December 16th, 2015, 04:22 PM
joe39562 joe39562 is offline
Viewer
Any chance you can make this work for the Trane Comfort Link II XL950 and American Standard AccuLink™ Platinum 950 Control? There the same just with different brands. I have the American standard (I saw someone earlier in the thread asked about the Trane). They are a nice hvac system but it uses a 3 wire control so cant just switch the thermostat. The 950s have built in wifi so I would think that the data could be accessed?
  #26
Old December 16th, 2015, 08:41 PM
kingfetty's Avatar
kingfetty kingfetty is offline
Seer Master
Quote:
I'm unable to find a published API document for either of those.
  #27
Old November 30th, 2016, 12:35 PM
spknapp's Avatar
spknapp spknapp is offline
Seer Master
Quote:
Originally Posted by spknapp View Post
Is the CT-80 supported and its extra features (humidity get/set, data areas)?
Steve
Quote:
Eric - any progress made on supporting the additional features of the CT-80 (humidity and user areas) or do you have any time frame in mind for these features?
Steve
(System configuration is in my profile)
  #28
Old December 1st, 2016, 12:40 PM
kingfetty's Avatar
Seer Master
It's still in my task list, but lately I've been battling some bugs with the plugin and some very odd circumstances. Once I reach stability on that front I will begin adding new features.
  #29
Old December 14th, 2017, 06:34 PM
spknapp's Avatar
Seer Master
Steve
Eric - what is the status of implementing the features that are missing from your plugin? I am referring to the basic features that you left out as well as the additional features of the CT-80 thermostat? It's been over a year since you addressed this question.
Basic features missing for all thermostats:
- Disable thermostat internal schedule
- Disable cloud reporting feature
- Price Messaging Area (PMA)
CT-80 features missing:
- Humidity control
- User Messaging Area (UMA)
- Control of night light (display backlight)
The plugin has been out for a while and yet these features are still missing.
Steve
  #30
Old December 14th, 2017, 07:09 PM
kingfetty's Avatar
Seer Master
- Humidity control
Steve
Honestly, I totally forgot, sorry. I appreciate the nudge. Let me see what I can do for you over the next couple weeks.
  #31
Old December 14th, 2017, 08:11 PM
spknapp's Avatar
Seer Master
Thank you.
  #32
Old December 16th, 2017, 04:57 PM
kingfetty's Avatar
Seer Master
New version posted specifically for stability and bug fixes. I'm still working on all your feature requests. Anything to do with the scheduling will take longer. For the immediate future my goal is to get things like humidity working for you.
  #33
Old December 17th, 2017, 06:09 AM
kingfetty's Avatar
Seer Master
Thank you.
Hey,
I need your help in testing out the functionality of the new features you had me put in place. I do not have access to any CT-80 thermostats to test the code.
I have pushed a new update out that has the following new features enabled:
New Device Types:
  • Humidity Sensor
  • Humidifier Control
  • DeHumidifier Control
  • NightLight Control
  • SaveEnergy Control
  • AirBaffle Control
New Actions available to events:
  • Reboot Device
  • Set Price Message Area
  • Set User Message Area
  • Set LED color
  • Set Remote Temperature Override
  • Clear Remote Temperature Override
I was able to test all the actions except the user message area as it's specific to the CT-80.
As for new device controls, I was unable to test any of them as the CT-30 and CT-50 does not have any of those features.
Please let me know the status of your testing so that I can make an official announcement that these features are now functional.
  #34
Old December 17th, 2017, 12:51 PM
spknapp's Avatar
Seer Master
Hey,
I have pushed a new update out ...
Should the new devices be created automatically? I updated to 1.0.17351.159 but I only see the original devices. Do I need to delete the devices and re-discover the thermostat?
I also don't see the new actions in the events.
What am I doing wrong?
  #35
Old December 17th, 2017, 01:47 PM
kingfetty's Avatar
Seer Master
Give the plugin a stop and a start real quick to make sure it started fresh.
Then go create a new event, drop down the action part not the trigger part and scroll all the way down. You should see something along the lines of this...
As for the new devices, yes their supposed to be created automatically, but as I stated I have absolutely no way to test them. I'm not very confident that those are working correctly. Let me see if I can throw in a way to have you dump some information for me to work from remotely so that I can test using a fake device.
  #36
Old December 17th, 2017, 02:18 PM
spknapp's Avatar
Seer Master
OK, I found the events and will play around with them for you, but I still don't have any new devices (humidity, etc.)
Am I still doing something wrong?
  #37
Old December 18th, 2017, 10:25 AM
Seer Deluxe
Hey,
New Device Types:
  • Humidity Sensor
  • AirBaffle Control
  • Reboot Device
  • Set LED color
Thanks for this update. This looks big. I'm going to test the remote temp this week.
  #38
Old December 18th, 2017, 10:29 AM
Seer Deluxe
Is there a way to use a variable or a value from another device for "Set Remote Temp Override"?
  #39
Old December 18th, 2017, 10:39 AM
kingfetty's Avatar
Seer Master
Not yet, it's on my todo list, but literally threw this in yesterday. Stayed up til 4am getting all those features in. My next round I'll include some abilities to map to variables, just as soon as I figure out how to do it. LOL
  #40
Old December 18th, 2017, 10:43 AM
kingfetty's Avatar
Seer Master
I haven't tried this yet, but we could try to use the built in variables
https://help.homeseer.com/help/HS3/s...ment_variables
$$DVAaddress):
Replacement is the VALUE of the device indicated by (address). For example, if the device at address R40 has a value of 100, then using $$DV:R40: in the text will result in 100 after the substitution.
$$DVCcode): Same as $$DVA but gets the device value using the device code.
$$DVRref): Same as $$DVA but gets the device value using the device reference number.
HTML code is Off
TR40 Serial Thermostat / Trane Thermostat / Heat Pump Bill Brower Thermostat / HVAC Discussion 0 October 14th, 2012 09:54 PM
Uppdated Radio Thermostat app skybolt BeakerStat 5 October 12th, 2012 07:11 PM
FM Radio gelessor Audio / Video and Infra-red (IR) Discussion 7 May 24th, 2010 11:54 PM
Pulling thermostat name by thermostat number-script simplecontrol ZWave 2 April 17th, 2010 02:00 PM
anyone own this radio shack weather radio with USB interface? Stevech Weather Discussion 9 April 1st, 2005 04:45 AM
