can you supply the driver to support the above router ?
ASUS AC66U Support
You will need to download the Router Logger app from my site and run it with your router in order to get some of the logging so I can see the format
http://bladeplugins.no-ip.org/Downlo...p#RouterLogger
Get it running and leave it running for a bit to capture some traffic
Then email me the log from the app.
Originally posted by computernerd View PostI also have the same ASUS Router AC66U with Tomato firmware. Is the router and tomato supported on the current release of BLRouterMonitor for HS3?
Blade, would you need me to run something on my router to give you system information?
Thanks!!!
hjk
Guest
I'm also running a router with tomato v1.28 by shibby although the hardware is netgear. Would love to get this plugin working with my router. Did this go anywhere? I can't seem to even get the router logger to capture anything.
Attached is a screenshot of the logging page on the router firmware.
help!!!
Guest
