Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HomeSeer DSC Plug-in
HomeSeer DSC Plug-in HomeSeer DSC plug-in for Power Series security panels
Old October 26th, 2017, 09:36 PM
Don J Don J is offline
Viewer
DSC pgm 1864
I'm trying to use 2 pgms to run different events so when I set the alarm is stay mode at the keypad it will turn some of the lights to 20%. Away mode all the lights off. Any suggestions would be greatly appreciated
So Far I set section 009 to 18 for stay mode pgm1
then 17 for away mode pgm2 this will give me 13.5 volts for 5 seconds (the time can be adjusted in section 170) on the desired pgm
a relay to turn these into a dry contacts is easily done
I only need a recommended analog input that will run an event
Tags
dsc pgm
HTML code is Off
DSC 1864 with HS3 and monitoring via Envisalink? cheeryfool Security System Discussion 5 October 11th, 2017 02:46 AM
DIY replace old Brinks/ADT with DSC 1864 mocavo67 Security System Discussion 2 May 15th, 2015 11:05 PM
DSC 1864 plus? hunter69 Security System Discussion 3 October 13th, 2014 09:44 AM
DSC 1864 and IT-100 problems Ag99JYD Security System Discussion 5 April 19th, 2014 04:22 PM
