Looking for simple sketch to test HS3 connection.
    I am looking for a simple sketch to test my connection with HS3 over Ethernet. Perhaps a sketch where I can control the flash rate of the onboard LED with the dimmer slider in HS3.
    If you are using the plug-in it is easy. Set an output pin, connect an LED through a resistor to it and set the output to blink. I use an input and output on each board, connect them together, then when the output is toggled, the input will report back from the board.
