Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old April 7th, 2018, 11:52 AM
HAorso33 HAorso33 is offline
Having some trouble adding NodeMCU
hi,
I'm having some trouble adding my nodeMCU. I'm trying to follow this help guide http://homeseer.dyndns-remote.com:87...eer%20Help.pdf
I'm unable to select NodeMCU as a board type in the plug-in.
To add a NodeMCU board to the plugin:
1. In the Arduino IDE go to File, Preferences. Under Additional Boards Manager Urls add
http://arduino.esp8266.com/staging/p...com_index.json then click OK.
2. In the Arduino IDE go to Tools, Board, Board Manager and search for nodemcu and click install
to install the board V2.3.0-rc2
3. In the Plugin you should select NodeMcu as your board type for a new board.
Some help and insight would be much appreciated :-)
Old April 7th, 2018, 11:54 AM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
What Version of the plugin are you using? You need the Beta version from the updater.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Old April 7th, 2018, 12:02 PM
Trial version, 1.0.0.131, will try the beta, thanks!
Trouble adding 2nd Z-Net as a Secondary Controller Wazoo Z-NET 37 April 7th, 2018 04:18 PM
Trouble adding Aeotec Meter demetri90 HomeSeer Help 1 February 2nd, 2018 06:05 PM
Trouble adding Yale Lock Mr_Resistor Lighting & Primary Technology Discussion 38 December 10th, 2011 10:19 AM
Trouble adding sensors jello4 MCS Temperature 5 April 23rd, 2010 07:51 PM
Trouble adding New Device... chucknewell HS2 / HSPRO 0 August 20th, 2005 08:48 PM
