Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old May 10th, 2018, 04:13 PM
parbas parbas is offline
Big Red Button
I have a big red button like this that I'm wanting to connect with HomeSeer to trigger an event.
Is there a way with an Arduino that I can trigger an event when the circuit is closed (button pressed)?
Old May 10th, 2018, 05:08 PM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
Yes, this is the kind of think the Arduino is used for. It takes contact closure in and out of Homeseer devices and you can act on this in events.
If you need any more help or info then get in touch.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Old May 10th, 2018, 05:09 PM
rprade's Avatar
rprade rprade is online now
Sure.
  1. Connect the switch between an Arduino pin and ground
  2. Assign that pin as an input in the Arduino configuration
  3. Create an Event with the trigger "Arduino pin changes and becomes Closed"
  4. Execute the desired actions in the Event
Randy Prade
Aurora, CO
Prades.net
Keypadlinc - Button controlling a scene that contains another button? dandrzejewski Insteon Plug-in (Mark Sandler) 1 December 7th, 2014 12:03 PM
Any idea how to activate button LED without turning on button? mpovolo Insteon Plug-in (Mark Sandler) 8 February 14th, 2014 10:34 AM
8 Button keypad showing up as 6 button thedishking Insteon Plug-in (Mark Sandler) 1 September 12th, 2010 03:43 PM
Press button make timestamp/show button pressed time PietjeNL HSTouch™ 2 June 28th, 2010 09:59 AM
Difference between Nexa one-button and two-button switches? Moskus RFXCOM Plug-In (3P) 4 March 19th, 2010 03:29 AM
