Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old May 12th, 2018, 02:03 AM
actibus actibus is offline
Connection error, but still works
Edit - it happens with both my wired arduino boards
The last week or so the plugin fails to connect to one of my arduino boards (Mega board with ethernet), or it says connection failed, but I can still send commands to the boardt but not receive.
I have tried to reflash it.
When disabling and re enabling the plugin it says connected for about 30-60 sec then says disconnected.
I also have a NodeMcu connected, it works fine
I tried to install the plugin on a fresh HS install and created a duplicate board, it connected and stayed connected, so the issue must be with my current installation.
Any way to do a fresh install of the plugin, without loosing my boards?
HS v435
Plugin v147
Old May 12th, 2018, 03:59 PM
Here is a debug log from right after disable -> enable plugin
Old May 13th, 2018, 11:02 AM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is offline
Super Seer
From the Debug it looks like a problem in your API Code that is flooding the plugin with data. You need to only send data when your value changes on the board or after x number of seconds but it looks like you are sending on every loop.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Connection Error - Connection Failed Conrad_Turbo Arduino Plugin (3P) 8 August 17th, 2015 06:46 AM
Error Serializing / Error Creating Connection mdavison MyHS Remote Access Service 0 February 19th, 2015 03:27 PM
GC100 Works but looses HS Connection? GaryA HomeSeer Global Cache Plug-in 16 April 19th, 2013 02:11 PM
Error but it works dhellis HmeSeer RainRelay8 Plug-in 0 January 26th, 2010 09:56 AM
local speaker looses tts but sample demo works...HS lost its connection ?? Richard HS2 / HSPRO 2 September 24th, 2005 07:28 PM
