Hi there, I bought this plugin but so far nothing but problems. I go to the JowiHue config page, and it will say Bridge Found at 192.168.1.80 which is fine. I press register, it says push the button, I do, and all my lights appear. Works perfectly fine. Day or so goes by, all Hue lights so Unreachable. I go into the plugin settings, it's right back to where it was, saying Bridge Found at 192.168.1.80 with the Register Bridge button.
Why do I have to register the bridge daily? I literally haven't even touched anything. If I use the Hue app I can control the lights just fine, but when I go back to HS3 it always shows not registered and acts like it never was, even though there's all the devices it created listed just showing Unreachable. My logs just show this over and over:
Aug-28 10:56:18 PM JowiHue Warning: SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed
Aug-28 10:52:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 10:37:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 10:22:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 10:07:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 9:52:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 9:37:05 PM JowiHue Info: -- Unregistered bridge found on network at 192.168.1.80
Aug-28 9:37:05 PM JowiHue Warning: SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed
Aug-28 9:24:24 PM JowiHue Error: (ShutdownIO):Error ending JowiHue Plug-In
Aug-28 9:24:24 PM JowiHue Error: (ShutdownIO):Object reference not set to an instance of an object.
Aug-28 9:24:00 PM JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page
Aug-28 9:23:59 PM JowiHue bridge 37 City Street is known as bridge, but is now unregistered. Please reregister through the configuration page. Or remove this bridge device?
Aug-28 9:23:59 PM JowiHue bridge 37 City Street ip address is 192.168.1.80
