download successful, wont show up in my plug ins... hs3... see attached screen shot
install plug in issues
Originally posted by gfs View Posthow do i install net 4.5???
Originally posted by gfs View Postdone loaded authorized but cant get devices to show up
ecobee shows up in my room list
but no devices when i check it
If you can't figure it out, please set the log level to Debug from the Config page, then post your logs when you restart the plugin. Thanks
Originally posted by thutchins View PostI am also having an issue with the plugin showing in the plugin mgr. I am running on the HS SEL troller with Linux. I thought .NET was only for Windows. Can I install on Linux?
Can you describe with more details what issue you have? Please post what you have in the logs.
thanks
I download Ecobee from the plugin mgr and it seems to install, but the Ecobee plugin does not then appear in the plugin mgr. Here is the error code from the log
n-15 8:29:24 AM Error Error, Creating plugin instance: HSPI_Ecobee.exe->Exception has been thrown by the target of an invocation.->Could not load file or assembly 'System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies.
Jan-15 8:29:23 AM Updater Install/Update of package Ecobee was successful.
Jan-15 8:29:23 AM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\\Ecobee.ini
Jan-15 8:29:23 AM Updater Extraction Complete.
Jan-15 8:29:23 AM Updater Extracting files from zip file: images.zip
Jan-15 8:29:23 AM Updater Copying file: \usr\local\HomeSeer\bin\Ecobee\System.Time.dll
Jan-15 8:29:23 AM Updater Copying file: \usr\local\HomeSeer\bin\Ecobee\Ecobee.Net.dll
Jan-15 8:29:23 AM Updater Copying file: \usr\local\HomeSeer\bin\Ecobee\Newtonsoft.Json.dll
Jan-15 8:29:23 AM Updater Copying file: \usr\local\HomeSeer\HSPI_Ecobee.exe.config
Jan-15 8:29:23 AM Updater Installing package Ecobee
Jan-15 8:29:23 AM Updater Update HSPI_Ecobee.exe downloaded successfully
Jan-15 8:29:21 AM Updater Downloading update: Ecobee
Jan-15 8:29:21 AM Updater Starting download of updates
Originally posted by thutchins View PostDo I need to install Mono? If so, how do I go about it? Linux newbie here!
however for this plugin to work you need mono 4. or later
check the version of mono installed with this command:
mono --version
also you may need to move 2 dlls from your homeseer dir to the bin folder
Code:sudo mv /usr/local/homeseer/Mono.CSharp.dll /usr/local/homeseer/bin/Mono.CSharp.dll sudo mv /usr/local/homeseer/CSScriptLibray.dll /usr/local/homeseer/bin/CSScriptLibrary.dll
version of Mono is : Mono JIT compiler version 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4)
tried running coy commands and got the following errors
homeseer@hometrollerSEL:~$ sudo mv /usr/local/homeseer/Mono.CSharp.dll /usr/local/homeseer/bin/Mono.CSharp.dll
[sudo] password for homeseer:
mv: cannot stat '/usr/local/homeseer/Mono.CSharp.dll': No such file or directory
homeseer@hometrollerSEL:~$ sudo mv /usr/local/homeseer/CSScriptLibray.dll /usr/local/homeseer/bin/CSScriptLibrary.dll
mv: cannot stat '/usr/local/homeseer/CSScriptLibray.dll': No such file or directory
Tom
Originally posted by thutchins View PostSpud,
I finally got remote access to my SEL so I checked on the 2 .dll 's you suggested moving. They are located in the /usr/local/HomeSeer/bin/ directory. Is that correct?
Tom
so, I'm not sure what's wrong...
you can try to install possible missing packages by running this command:
Code:sudo apt-get install mono-complete
