can't control nest thermostat
    could you install version 3.0.0.22 available here It has better logs for this kind of errors.
      i did,
      the updater still show .21
      DEBUG event: keep-alive
      dec-19 20:22:51 Nest DEBUG data: null
      dec-19 20:22:51 Nest DEBUG event: keep-alive
      dec-19 20:22:26 Nest DEBUG data: {"path":"/","data":{"devices":{"thermostats":{"gi6tL1If6GjEXBc6t9o-2A_VumSUMP-v":{"humidity":50,"locale":"nl-NL","temperature_scale":"C","is_using_emergency_heat":false, "has_fan":false,"software_version":"5.6-7","has_leaf":false,"where_id":"e4FzI0k3ounJK98jBApsiD3MQnKh HOEzrxhFivj_GTGqA1DwGeRj6A","device_id":"gi6tL1If6GjEXBc6t9o-2A_VumSUMP-v","name":"Living Room","can_heat":true,"can_cool":false,"target_temperature_c ":20.0,"target_temperature_f":68,"target_temperature_high_c" :24.0,"target_temperature_high_f":75,"target_temperature_low _c":20.0,"target_temperature_low_f":68,"ambient_temperature_ c":19.5,"ambient_temperature_f":67,"away_temperature_high_c" :24.0,"away_temperature_high_f":76,"away_temperature_low_c": 15.0,"away_temperature_low_f":59,"structure_id":"X1tlsoj_Fc5 v4spDLm3QoVnvXfGSWpwGBBSQY2d3hHiDG_gZkmj1mA","fan_timer_acti ve":false,"fan_timer_timeout":"1970-01-01T00:00:00.000Z","hvac_mode":"heat","name_long":"Living Room Thermostat","is_online":true,"last_connection":"2016-12-19T19:22:26.707Z","hvac_state":"heating"}},"smoke_co_alarms" :{"cw2LlF6qsbI6-k1zp5AQ7w_VumSUMP-v":{"name":"Kitchen","locale":"nl-NL","structure_id":"X1tlsoj_Fc5v4spDLm3QoVnvXfGSWpwGBBSQY2d3 hHiDG_gZkmj1mA","software_version":"3.1rc9","where_id":"e4Fz I0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTGgoDbPcAiiOw","device_ id":"cw2LlF6qsbI6-k1zp5AQ7w_VumSUMP-v","name_long":"Kitchen Nest Protect","is_online":true,"last_connection":"2016-12-19T13:39:01.395Z","battery_health":"ok","co_alarm_state":"ok ","smoke_alarm_state":"ok","ui_color_state":"green","is_manu al_test_active":false,"last_manual_test_time":"1970-01-01T00:00:00.000Z"}}},"structures":{"X1tlsoj_Fc5v4spDLm3QoVnv XfGSWpwGBBSQY2d3hHiDG_gZkmj1mA":{"smoke_co_alarms":["cw2LlF6qsbI6-k1zp5AQ7w_VumSUMP-v"],"name":"Thuis","country_code":"NL","time_zone":"Europe/Amsterdam","away":"home","thermostats":["gi6tL1If6GjEXBc6t9o-2A_VumSUMP-v"],"structure_id":"X1tlsoj_Fc5v4spDLm3QoVnvXfGSWpwGBBSQY2d3hHi DG_gZkmj1mA","wheres":{"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhF ivj_GTEQbYDGG26IUQ":{"where_id":"e4FzI0k3ounJK98jBApsiD3MQnK hHOEzrxhFivj_GTEQbYDGG26IUQ","name":"Backyard"},"e4FzI0k3oun JK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw":{"where_id":"e4 FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTFP3uSH6epqyw","name" :"Basement"},"e4FzI0k3ounJK98jBApsiD3MQnKhHOEzrxhFivj_GTHDWa hECEab0A":
        version .22 is not in the updater, you have to install it manually as explained in this post: http://board.homeseer.com/showthread.php?t=169467
          i did, see post above
          if you want to login, just let me know
            the logs you posted above do not show any error at all, and they don't say if you have version .22 installed or not. Disable then enable the plugin the first log lines should show the version of the plugin running.
                what version of .NET do you run?
                one other user had this same problem with .NET 4 and updating to NET 4.5.1 fixed it: http://board.homeseer.com/showthread.php?t=171113
                  i did the update to 4.5.2 and now it works
                  thanks!! i never tought of this myself
