Status not Changing
Originally posted by huntley1 View Post[ATTACH]58963[/ATTACH]
please keep the debug log enable (you can use the log to file option) until it doesn't work and then send them to me.
for some reason the movie you play doesn't have an id, what is the source of this movie, do you have it in your library?anyway you can safely ignore this error, I will make it disappear in the next version.
thanks
Originally posted by huntley1 View PostWhen I download the files onto my controller (running Linux), the update doesn't show in the Plug-In manage as instructed to.
There is just a main applications folder on my machine, there is no updates folder.
Originally posted by huntley1 View PostI get it to the point where it asks to download and install, but the install fails.
I'm not 100% sure where to put the Override.txt file. i have it installed /usr/local/HomeSeer
check your logs to know why the installation fails
Here are the logs for when I try to do the download:
A folder with the name Kodi3.0.1.1 is created in the /usr/local/Homeseer/Updates3 folder, but has no file in it. I the download and install unzips the Kodi_Linux_3-0-1-1.zip file, creates the Kodi3.0.1.1 folder, and moves the file into there. I manually tried doing it, but I keep getting a prompt saying I don't have permission...
Originally posted by huntley1 View PostI get this prompt when I try to move it into the Zip folder. Even when trying to save the download directly there.
[ATTACH]59010[/ATTACH]
I finally got the zip file copied into the Zips folder. I have to open /usr/local/HomeSeer/Updates3 in a terminal and used the following commands(ignore the last two lines):
The password is hsthsths3
I go the update installed and is seem to working quiete well. I have yet to see an issue with the status update. I'll keep a close eye it over the weekend and let you know for sure.
Thanks for your help!
Originally posted by macrho View PostHaving the same problem here. Running 3.0.1.2 and my status never changes even though the plugin is connected. Even tried sending a text and nothing gets through. Running Kodi 16.1 on a Windows 10 machine
To check that run the "Resource Monitor" (from Task manager click the Resource monitor button from the performance tab), and then find the program that listen on port 9090 from the "Listening Ports" section. Stop this program, and restart Kodi and then restart the plugin.
