I'm running 3.6.5.0 and I am still having problems with "Logitech web service response does not contain a login authorization token" errors. Things will work properly for a few weeks, then stop. This is the 2nd time it stopped working with the above error, after working properly. In both cases, the failure was triggered by config changes made by me. Once to my harmony device setup and this time to some networking changes (cable modem & router replacement).
Last time, I had to delete everything and reinstall. I'd prefer not to do this again. I have events linked to the devices now and would like to keep them.
Log:
Jan-22 8:18:08 AM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: LOGITECH WEB SERVICE LOGIN : FAILURE ERROR : harmonyWebServiceLogin : Logitech web service response does not contain a login authorization token -
Jan-22 8:18:08 AM Harmony Hub Plugin: Harmony Hub reference/status is : 78--Watch tv--Active--3
Jan-22 8:18:08 AM Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 78----Hub1=3
My HarmonyHub.AuthorizationToken in the homeseerHS3 directory file contains 'ThisisadummyToken'. I have never seen it have any other value, although I have never looked at it when things are working properly. I have no other copies of this file.
My harmony hub is at the proper IP address, as displayed by the harmony app. I can ping it. IP, Userid and password are correct in plugin config, I haven't changed them in weeks.
I get the same failing output when running the command line tool. I've run this tool on 2 different systems in my house with the same errors.
Hub version is 4.12.36. Is there any other debug information to collect?
The harmony hub itself works properly from the remote, the app and alexa (echo).
Log:
