i get the following errors upon JowiHue starting up. there are lots of The given key was not present in the dictionary. errors now i can see two of them are caused by two of my bulbs which are Living Whites bulbs (they are just dimmable white lights only) can you add those to the plugin?
the others i am not so sure, I have moved the devices to my own Floor and Rooms, as i saw other are also experiencing the same issue when changing the room/floor. allthough i do have lots of lights so i would have expected more errors if that was the case.
maybe light groups? anyway here is my startup log for JowiHue
09/05/2017 16:35:08 ~!~Plug-In~!~Found plug-in: JowiHue, version: 1.1.2.8 09/05/2017 16:36:02 ~!~Info~!~Plugin JowiHue has connected. IP:127.0.0.1:64389 09/05/2017 16:36:03 ~!~JowiHue~!~Starting plugin JowiHue 1.1.2.8 on Windows 09/05/2017 16:36:03 ~!~JowiHue~!~Starting plugin JowiHue 1.1.2.8 on Windows 09/05/2017 16:36:05 ~!~JowiHue~!~InitIO:Plugin basic initialisation done 09/05/2017 16:36:05 ~!~Plug-In~!~Finished initializing plug-in JowiHue 09/05/2017 16:36:11 ~!~JowiHue~!~* Connected to bridge Fuzzy-HUE at 192.168.xx.xx 09/05/2017 16:36:14 ~!~JowiHue~!~Error: (InitDevices):The given key was not present in the dictionary. 09/05/2017 16:36:14 ~!~JowiHue~!~Error: (InitDevices):Gathering information from device Outside Porch ref:1015 of type Light 09/05/2017 16:36:15 ~!~JowiHue~!~Error: (InitDevices):The given key was not present in the dictionary. 09/05/2017 16:36:15 ~!~JowiHue~!~Error: (InitDevices):Gathering information from device Tiffany Lamp ref:1017 of type Light 09/05/2017 16:36:21 ~!~JowiHue~!~Error: (UpdateGroup):The given key was not present in the dictionary. 09/05/2017 16:36:24 ~!~JowiHue~!~Error: (UpdateGroup):The given key was not present in the dictionary. 09/05/2017 16:36:28 ~!~JowiHue~!~Error: (UpdateGroup):The given key was not present in the dictionary. 09/05/2017 16:36:32 ~!~JowiHue~!~Error: (UpdateGroup):The given key was not present in the dictionary. 09/05/2017 16:36:34 ~!~JowiHue~!~Error: (UpdateGroup):The given key was not present in the dictionary. 09/05/2017 16:36:37 ~!~JowiHue~!~Warning: Unknown lighttype found:LWB010 Please report this type to plugin owner? 09/05/2017 16:36:37 ~!~JowiHue~!~============================================================================================== 09/05/2017 16:36:37 ~!~JowiHue~!~-------------------------------------Bridge info --------------------------------------------- 09/05/2017 16:36:37 ~!~JowiHue~!~29 lights connected to bridge 'Fuzzy-HUE' 09/05/2017 16:36:37 ~!~JowiHue~!~10 Groups available on bridge 'Fuzzy-HUE' 09/05/2017 16:36:37 ~!~JowiHue~!~3 TAP(s) found on bridge 'Fuzzy-HUE' with 3 supporting HS device(s) 09/05/2017 16:36:37 ~!~JowiHue~!~1 Daylight sensor found on bridge 'Fuzzy-HUE' 09/05/2017 16:36:37 ~!~JowiHue~!~-------------------------------------Plugin info --------------------------------------------- 09/05/2017 16:36:37 ~!~JowiHue~!~22 Presets available for use in the JowiHue plugin 09/05/2017 16:36:37 ~!~JowiHue~!~22 Presets available for use in the JowiHue plugin 09/05/2017 16:36:38 ~!~JowiHue~!~11 Local scenes available for use in the JowiHue plugin 09/05/2017 16:36:38 ~!~JowiHue~!~11 Local scenes available for use in the JowiHue plugin 09/05/2017 16:36:38 ~!~JowiHue~!~1 Animations available for use in this plugin 09/05/2017 16:36:38 ~!~JowiHue~!~Device of reporting bridge and light firmware updates is enabled 09/05/2017 16:36:38 ~!~JowiHue~!~============================================================================================== Line 217: 09/05/2017 16:36:38 ~!~JowiHue~!~Plugin succesfully started
