UI wired the main switch and the companion in a preexisting 3-way setup. It all works, the lights go on/off as supposed to , I programmed some multi key press actions and they all work too.
The only problem, minor, is that the companion switch's Mode LED never comes on, whereas the main switch's LED turns on when the switch is OFF - as has been programmed.
I tried adding the companion to the Z-Wave - did not see anything (did not expect it to - but tried it anyways). Am I doing something wrong, or missing something?
