I've been lurking around this board for a long time,both before and after my homeseer purchase, and you guys have helped me allot during the couple of month I've been into HA. Thanks!
The other day i bought a HSM100 and my first problem was that the temperature was displayed in Fahrenheit, witch i solved after a quick search in this forum. (added HSM100FORMAT = C to 2nd line of settings.ini)
But in a speak event it would still announce it as Fahrenheit (times 10). My solution to this was to write a script.
My first ever, so please be gentle if it looks bad: (took me a couple of hours of playing around, searching this board and google )
The script above will give you the temperature in whole numbers, so if you want decimals, change the last zero in:
to the amount of decimals you would like.
I hope that this could be of help for other scripting illiterates like me
Markus
Sub Main() Dim Celsius Celsius = round((((hs.Devicevalue("Q2")/10) - 32) / 1.8),0) hs.speak "Inside temperature is " & Celsius & " degrees" End Sub
Celsius = round((((hs.Devicevalue("Q2")/10) - 32) / 1.8),[B]0[/B])
Markus
