Ok, so I restarted HS today.
I have buttons to launch HSClients for the clients.
Button config is:
[VDButton14]
Buttontext=Start HSTouch
Command=run||hstouch.exe||||0||C:\Program Files\HomeSeer HSTouch
I get an error is HS Log -
2/24/2013 8:43:16 AM Error Initializing script run: File 'Jon00RCCNM.vben' not found.
Nothing in the Error.txt file on the client.
I have a button that calls a macro -
[VDButton12]
Buttontext=JBright
Command=macro3
[VDButton13]
Buttontext=JDim
Command=macro2
They call an exe on the client -
Macro2
run||C:\Progra~1\Backlight\JogglerBlCtrl.exe||1
Macro3
run||C:\Progra~1\Backlight\JogglerBlCtrl.exe||100
This works.
After clicking one of those buttons, button14 works.
However, not knowing it, if I place commands in the startup.txt file it works!
Currently commented out -
'hs.RunEx "Jon00RCCNM.vben","main","9||run||hstouch.exe||||0||c:\progr am files\Homeseer HSTouch"
'hs.RunEx "Jon00RCCNM.vben","main","10||run||hstouch.exe||||0||c:\prog ram files\Homeseer HSTouch"
'hs.RunEx "Jon00RCCNM.vben","main","11||run||hstouch.exe||||0||c:\prog ram files\Homeseer HSTouch"
'hs.RunEx "Jon00RCCNM.vben","main","12||run||hstouch.exe||||0||c:\prog ram files\Homeseer HSTouch"
'hs.RunEx "Jon00RCCNM.vben","main","13||run||hstouch.exe||||0||c:\prog ram files\Homeseer HSTouch"
Still no error.txt file on client(s).
I think in past testing I have restarted the RCC Client then tried clicking button14 and it worked. In other words, restarting the RCC client will fix the issue, too. I think.
Button config is:
[VDButton14]
[VDButton12]
Buttontext=JBright
Command=macro3
[VDButton13]
Buttontext=JDim
Command=macro2
Macro2
Macro3
This works.
