Hey there,
I have installed a bunch of these new HS switches and dimmers. In a couple of places, I found myself needing to associate them with the individual buttons on my Cooper Aspire five-button wall controllers. That means, I need the button to be associated with the HS dimmer set a a specified dim level. One problem. Despite the dimmer being absolutely correctly identified in HomeSeer and working very nicely from there, the Cooper Aspire wall controller sees it as a switch. That means, when I program a scene in each individual button, adding the HS dimmer to that scene only gives me the ON and OFF settings. That is it. i can not set a dim setting. If i try to add any other z-wave dimmer i have (Cooper, Leviton, GE), then it is seen correctly and I get the drop-down of a preset dim level to choose. Definitely sems like an HS firmware / software issue...
HS3 and all plugins are the latest available. Any suggestions?
