I picked this up on Amazon: Dresden wireless ballast FLS-PP lp with Power PWM interface, 3m RGB LED stripe and power supply. deCONZ found it just fine and I am able to control it from the web interface. But from JowiHue I can only control on/off and dim level. If I move any of the color sliders, the led strip turns off. The plugin sees it as type FLS-PP3.
The other problem is that when I try and open the Lights list in the Bridge Maintenance page, I get this in the log (and no list):
JowiHue Error: (BuildSliderLights):web Maintenance:Object reference not set to an instance of an object.
The Groups and other lists work fine.
There is a little bit more in the trace file.
14:17:02.9550530 -- (Web_Maintenance.BuildSliderLights) -C- Build slider lights for RaspBee-GW lightrows found = 13 14:17:02.9585620 -- (Web_Maintenance.BuildSliderLights) Error: web Maintenance:Object reference not set to an instance of an object. 14:17:02.9649980 -- (Web_Maintenance.BuildSliderLights) System.NullReferenceException(0x80004003): Object reference not set to an instance of an object. at HSPI_JowiHue.Web_Maintenance.BuildSliderLights (HSPI_JowiHue.HueDataSet+MyBridgesTableRow& Bridgerow, System.Boolean Rebuilding, System.Boolean Close) [0x005a6] in <e0e8eeffe1ad4e3e9590b78780b6c2a1>:0
