OMNI Plugin v3.0.2.12
    v3.0.2.12 was released to the updater today.
    Changes in this version:
    • Added Somfy ILT Shades to unit selection
    • Added dimming steps 1-9 for Standard/Extended/X10 Units
    Always make a backup of your system before loading a new version.
    Post any issues you have with this version in this thread.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
    The plugin is now in the updater...
      Reserved 2
        Updated HS3 Pro and Lite to version 3.0.2.12 this afternoon. No issues with update.
        Thank you Rob!!!
          Any other feedback from users?
          I think there is one item left for X10 where when already dimmed to 50% an increase or decrease is not working. I might be able to use Dim/Brighten for handling this.
          Any UPB dimming feedback?
            No feedback on dimming, it's working fine for my ALC lights.
            Next time you're putting out an update, can you fix the value on zones that are secure-bypassed? They come across as a -1 which isn't right. Thanks!
              Ah - will do - thanks!
                Hey Rob, looks good here. I do see something small though. When operated by voice, “Alexa, dim the master bedroom light to 20%” yields 21% in both SnapLink Mobile and in the HS Unit Device. Is that a scale problem or programming thing? Some values are perfect an other values are off by 1 as well. Seems like a rounding/scale issue again. What say you?
                -Travis
                  I do know that X10 dimming uses the dim steps 1-9 whereas the other technologies use a percentage. Let me play around and see where that percentage is coming from.
                    Hi, Rob. Everything working well here. I still don't have access to Zones in the EE. When might you have a chance to work on that?
                      I'm trying to get a build ready for later this week. Stay tuned to this thread.
                        New version posted:
                        https://forums.homeseer.com/showthread.php?t=196258
