Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraGCIR HSPI
UltraGCIR HSPI Discussion area for the UltraGCIR HSPI plugin.
Old November 4th, 2012, 11:56 PM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
OverSeer
UltraGCIR HSPI - Feature Requests
Please post your feature requests here.
Regards,
Ultrajones
Old August 10th, 2014, 08:23 PM
Noah
Guest
Posts: n/a
Thumbs up Feature Request
GC-100 Serial Port Support (as of HS3 it has become a royal PITA), Linux Support (for all plugins i might add!), and connectivity to the global cache IR database to download known codes.
Love the import feature. It is a HUGE time saver.
Noah
Old September 14th, 2014, 10:48 PM
Tim.Kieschnick Tim.Kieschnick is offline
Seer
LED Lighting
Support for the set_LED_LIGHTING command. Section 5.4.3 of http://www.globalcache.com/files/docs/API-iTach.pdf
I don't really care about ramp rate, only setting the % intensity.
Old September 15th, 2014, 07:44 PM
Ultrajones's Avatar
OverSeer
Wow, this is the first I heard of this. How are you connecting LED lighting to the Global Cache iTach?
Old February 5th, 2015, 04:30 PM
neutron neutron is offline
Seer Plus
Toggle on Contact Closures
Hi, It would be really nice if you could add a toggle active/inactive on the contact closure devices so that from HSTouch we could set a button to toggle the device hooked easily.
Scott
Neutron Digital Solutions
Old February 15th, 2015, 10:26 AM
Ultrajones's Avatar
OverSeer
Quote:
This feature will be available in the next release. If the Linux testing goes well, I'll be posting the update within a week.
Regards,
Ultrajones
Old February 16th, 2015, 08:54 PM
Seer Plus
Quote:
Regards,
Ultrajones
Old March 28th, 2015, 04:20 PM
Seer
LED lighting, different solution
I never did get LED lighting to work with the GC iTach. I have stopped trying and am now using a few of these: http://www.fibaro.com/us/the-fibaro-...gbw-controller Support in HS isn't spectacular yet but the Z-Wave plugin .216 gets me close enough.
Old October 3rd, 2015, 11:32 PM
rileydogmi rileydogmi is offline
Seer Deluxe
Just trying the plugin out - have 12 GC's, and all were created. But, I have no idea how to determine which one is which. Can the IP address of the device be added to the UltraGCIR3 tab so I can determine which one I am working with? Thanks!
Old October 5th, 2015, 11:50 AM
Gallina's Avatar
Gallina Gallina is offline
Seer Deluxe
existing ircodes
Can the plugin retrieve codes in the GC DEVICE. All the devices(5) have all the codes I need. They show up in the plugin as having no data.
HS3PRO
HP DESKTOP SSD I7
WIN 10
Old December 13th, 2015, 08:14 AM
NicolaiL's Avatar
NicolaiL NicolaiL is offline
Super Seer
Would be great if the "Global Cache Ignore List" could be filtered by MAC address (in addition to the current IP address).
That would be helpful when you temporarily add a new device to your network, but it hasn't yet been configured (and you don't know what IP address it is going to grab from the DHCP server).
Old December 20th, 2015, 09:42 PM
RMan54 RMan54 is offline
Seer
It would be very nice if different devices with their respective IR code sets could be assigned to a single IR emitter port, with their own imports of the IR code sets. This would make it much easier to set up the use of IR blasters that emit to several devices at the same time. Right now, the workaround is to rename the IR code signal names which is rather tedious.
Rene
Old December 27th, 2015, 11:35 PM
MrWassen MrWassen is offline
Seer
Impressive plugin but as always there are a few annoyances/inconveniences that would be nice to have addressed, both related to the import function:
1) Option to append or overwrite when importing an IR file. Currently an imported file will always overwrite all existing entries for a given port.
2) Option to prefix the device name when importing a set of commands, for example if there are 25 functions for a device, e.g. 29" LG TV:
POWER_ON
POWER_OFF
CHANNEL_UP
etc.
the user could input an optional prefix of "LG29TV_" in a "Prefix" prompt in the import tab, then the loaded IR commands would be re-named to:
LG29TV_POWER_ON
LG29TV_POWER_OFF
LG29TV_CHANNEL_UP
etc....
This would make it much more user friendly to select the device suboption when creating an event.
Again, thanks for the plugin
Dennis
Old December 27th, 2015, 11:42 PM
Seer
... and the 3rd idea is:
3) Instead of having a separate IR control tab showing a dump of the controls as buttons side by side (very difficult to view and select from if many are present), simply add a "Test" option next to each entry in the "IR Device" tab (and get rid of the IR control tab altogether), so you would see:
LG29TV_CC sendir,$MODULE,1,38000,1,69,340,169,20,20,20,20,20,20,20,20, 64,20,64,20,20,20,64,20,64,2...Test / Edit / Delete
for each entry.
HTML code is On
