Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraGCIR HSPI
UltraGCIR HSPI Discussion area for the UltraGCIR HSPI plugin.
Old September 29th, 2016, 05:46 AM
martin@datase.co.uk martin@datase.co.uk is offline
Seer
Text box string length.
Hi UltraJones, I just have one issue with trying to past the sendir:xxx string into the text box of your (licensed) plugin, it seems it only takes up to a fixed number of characters.
I'm trying to paste the codes for a 'LONG POWER ON' for a Panasonic TV but the text box won't let me.
Any ideas please?
Kind regards
Martin
Old October 2nd, 2016, 10:13 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
OverSeer
Hello Martin,
I am not sure what textbox you are referring to. Can you provide a screenshot?
Regards,
Ultrajones
Old October 3rd, 2016, 06:06 PM
Seer
Hi Ultrajones, I mean the IR Button Data: box where you paste/enter the IR Code. It seems it's limit is 1024 characters which is normally more than adequate for most strings.
Unfortunately the IR code for the Long Power On for my Panasonic TV is 1235 characters (which I admit is ridiculous):
sendir,1:1,1,37000,1,1,128,63,16,16,16,48,16,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16,48, 16,48,16,48,16,48,16,16,16,16,16,16,16,48,16,48,16,48,16,48, 16,48,16,16,16,48,16,2712,128,63,16,16,16,48,16,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48,16, 48,16,48,16,48,16,48,16,16,16,16,16,16,16,48,16,48,16,48,16, 48,16,48,16,16,16,48,16,2712,128,63,16,16,16,48,16,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,48, 16,48,16,48,16,48,16,48,16,16,16,16,16,16,16,48,16,48,16,48, 16,48,16,48,16,16,16,48,16,2712,128,63,16,16,16,48,16,16,16, 16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 48,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16,16, 48,16,48,16,48,16,48,16,48,16,16,16,16,16,16,16,48,16,48,16, 48,16,48,16,48,16,16,16,48,16,2712
Is there any way round this please?
Kind regards
Martin
Old October 3rd, 2016, 06:16 PM
Ultrajones's Avatar
OverSeer
This is going to take a day or two to fix... I need to figure out the command to increase the size of the database field and also change my code to allow IR data greater than 1024.
Regards,
Ultrajones
Old October 4th, 2016, 06:52 PM
Seer
RE: Text length
Thank you Ultrajones.
Hopefully that'll be the maximum length that any IR device uses.
Martin
Old October 14th, 2016, 02:39 PM
Seer
Hi Ultrajones, any news Sir? Any update you want me to try I'll install and test.
Martin
Old October 15th, 2016, 01:45 AM
BlairG's Avatar
BlairG BlairG is offline
Seer Deluxe
Looking at your IR code string it seems that your sending the same string 4 times.
The large number 2712 is a terminating number to the code string.
Blair
HomeSeer: HS3 Pro 3.0.0.425
Hometroller S6 | Devices: 567 | Events: 191
Plug-Ins: Z-Wave .190 | HSTouch | RFXCOM | UltraRachio3
BLLAN | NetCAM | Global Cache Pro | Sonos | FitBit Seer | SDJ_Health
Old October 15th, 2016, 08:25 AM
Seer
That's the code I got from the GC Database, our Pana TV won't come on until you've held the power on button on the remote for a good few seconds.
It seems ridiculous to me too but it's what I'm stuck with unfortunately.
If anyone knows of a another code that's less than 1024 chars I'd be happy to use that instead.
Martin
Old October 15th, 2016, 09:12 AM
Ultrajones's Avatar
OverSeer
I modify the program to support 2048 characters in the irdata field. You'll need to download UltraGCIR3 version 3.0.6132.16975.
Regards,
Ultrajones
Old October 15th, 2016, 09:25 AM
Ultrajones's Avatar
OverSeer
Wow, SQLite appears to ignore the varchar size. Don't delete the database and start over. The updates to the plug-in should be enough to resolve the issue you reported. I updated the post above to exclude the step to delete the database and start over.
Old October 16th, 2016, 05:15 AM
Seer
Good morning, thank you for this.
I've installed the update but the text box still cuts off remaining characters for some reason.
Is there something else I need to do?
I did disable and then enable the plugin.
Martin
Old October 16th, 2016, 05:24 AM
Seer
Scrub that last post, it must have been Chrome caching the text box somehow. I just tried in IE and successfully pasted the whole of the IR code.
I will test this evening my full scene for power on, switching inputs, waiting for the Sky+ box to fully power up etc. and let you know.
Thank you so much for your work on this and apologies on behalf of Panasonic for such a ridiculous IR code in the first place.
Martin
HTML code is On
GetURL text string compare - help needed jabrans Script & Plug-In Development 12 December 6th, 2015 04:15 AM
HOWTO ,DSA Using partial string text in device ? Malosa HS3 / HS3PRO Discussion 0 February 7th, 2015 11:37 AM
Length of text announcement? VirtualPanther AirplaySpeak 3 January 19th, 2015 12:15 PM
Text to Speech a Device String - Works travisdh HS3 / HS3PRO Discussion 4 December 28th, 2013 01:47 PM
Displaying Text String from a Script ediehl HSTouch™ 2 February 15th, 2009 07:48 PM
