Anyone try the vents from Flair yet?
Flair vents
As someone who works in energy efficiency on both a residential and commercial scale I can't recommend these devices. Ductwork is specifically designed. Well at least it should be....... If you close a register you create imbalances throughout the system. The only safe way to have the resolution of controlling one room is to have that room on its own zone.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Originally posted by S-F View PostAs someone who works in energy efficiency on both a residential and commercial scale I can't recommend these devices. Ductwork is specifically designed. Well at least it should be....... If you close a register you create imbalances throughout the system. The only safe way to have the resolution of controlling one room is to have that room on its own zone.
Looking into these myself and Flair looks like the best post construction option from my limited research so far.
Originally posted by MSG56 View PostAny updates on integrating flair with HS via ecobee?
