Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > Ecobee (3P)
Ecobee (3P) Discussions related to the Ecobee plugin by Spud
Old November 21st, 2017, 12:59 PM
Michel Michel is offline
Seer Deluxe
Multiple Ecobee3 Lite
Hi Spud,
Just bought my first Ecobee3 Lite and trialing your plug-in. Ultimately in spring, my system will have (2) Ecobee 3 Lite and I'm wondering if your plug-in will "see" that 2nd unit and created a new group for it?
Thanks.
Old November 21st, 2017, 01:18 PM
spud's Avatar
spud spud is offline
Moderator
Yes the plugin will see the 2nd thermostat and create a new set of device accordingly.
Old November 23rd, 2017, 05:41 PM
Seer Deluxe
Thanks Spud. I was hoping to see this PI in this week 20% off Black Friday sale in order to alleviate some of our CAD exchange but it's not. Your decision or HS?
Old November 23rd, 2017, 06:52 PM
spud's Avatar
Moderator
my decision
Old November 25th, 2017, 12:24 PM
aldo's Avatar
aldo aldo is offline
Super Seer
Spud on similar subject, can I change the category, room name, the name of the sensor and the category? I'm adding two extra sensors.
Aldo
Old November 25th, 2017, 01:15 PM
spud's Avatar
Moderator
Quote:
Aldo
sure, you can change the name, location or type of an Ecobee virtual device to anything you want. The plug-in will still work as expected.
Old November 25th, 2017, 01:54 PM
aldo's Avatar
Super Seer
Quote:
Spud you are the best, thank you.
Sent from my SM-G935V using Tapatalk
Old December 2nd, 2017, 08:47 AM
Seer Deluxe
One more question.
I'm still working on what brand of Dual zone Cool/Heat heat pump, I will buy. The external thermostat control is an important part of my decision.
I had LG and Mitsubishi in mind because that have 3rd party thermostat interface. I had even purchased a first Ecobee3 Lite that I returned because after writing to LG, they confirmed that in 3rd party control I would loose the compressor inverter (modulation) capability. i.e. the compressor would only work on a all or nothing mode.
I'm now looking at Daikin since they are selling a thermostat (Daikin Envi) that they had manufactured by Ecobee. It is based on the Smart Si model but with proprietary two-wires data communication to their indoor unit instead of dry contacts. The thermostat has more of a year 2000 look then the Ecobee3 but offers much better and specific interaction.
In the manual they refer to a Daikin portal but it seems to still be Ecobee in the background, branded to Daikin. Even the software user agreement is with Ecobee. However, the mobile app seems to be a dedicated Daikin app and not the Ecobee one. So I'm wondering if Daikin thermostat are exposed to the same Ecobee API that Spud is using.
So my questions are :
Have you Spud heard about peoples using your plug-in with a Daikin Envi thermostat?
Same question but to other users and if so, are you happy with it?
Old December 2nd, 2017, 09:03 AM
spud's Avatar
Moderator
Quote:
No I haven't heard of anyone using the plugin with a Daikin Envi
In the API docs, it says that Daikin is one of the brand supported: https://www.ecobee.com/home/develope...brandsFeatures
but it doesn't say exactly which models implement the API, so I don't know if this particular thermostat will work with the plugin.
Old December 2nd, 2017, 09:39 AM
Seer Deluxe
Spud,
Thanks for the prompt reply and for sharing that developer link.
The fact that is is showing in the "Thermostat Brands and Features" section is encouraging. However it is not specifically listed in the "Thermostat Models" or "Account Types/Smart" sections as Carrier and Bryant are.
I'll see if other users have been. If not, I'll try to see with Ecobee.
I still need to confirm with Daikin that the temperature sensing is based from the thermostat sensor and not from the wall hanging unit.
Ultimately, I may try to get a demo unit from a potential Daikin vendor. If I do, there are little chances of seing this happen within (20) days and after that my trial will be over. Do you have a way to reactivate a trial for a few days?
Regards.
Old December 2nd, 2017, 11:12 AM
spud's Avatar
Moderator
You will need to ask HS support for a new trial licence, this should not be a problem.
Old December 3rd, 2017, 06:19 PM
Seer Deluxe
Here's the reply from Ecobee. Prompt but not the resolution I was hoping for. I'll give a try with Daikin but have little hope.
ecobee Support (ecobee Support)
Dec 3, 4:50 PM EST
Hello Michel, thank you for contacting ecobee customer support.
While we do manufacture the Daikin Envi I'm afraid the back-end for that unit is very different from our own thermostats and other similarly branded thermostats. Sadly the Envi does not have the same API support as that is all handled by Daikin themselves. In order for an external service to be compatible with that thermostat Daikin would need to provide that support, it may still be worth reaching out to them however, they may have support currently for your HA solution or be planning support in future.
Regards,
HTML code is Off
Nest to ecobee3: Need some advice/guidance ryanborstelmann Ecobee (3P) 2 June 26th, 2017 03:00 PM
More than one (2) Ecobee3's at same location stevenslosangeles Ecobee (3P) 2 June 29th, 2016 01:19 PM
Black Friday: $64 off coupon on Ecobee3 smarter bundle spud Ecobee (3P) 0 November 24th, 2015 11:30 AM
Ecobee3 fpebrian Thermostat / HVAC Discussion 11 October 27th, 2015 02:03 PM
W2C or W2C lite? completelyhis Way2Call Hi-Phone (Hardware Interface) 6 December 29th, 2010 02:39 PM
