UltraGCI HSPI For HomeSeer [NEW]
    UltraGCI for HomeSeer 2:
    UltraGCIR is a HomeSeer HS2 plug-in that allows you to use HomeSeer to control IR and relay devices, such as televisions, AV receivers, Blu-ray players, motorized blinds and more. The UltraGCIR also allows event based triggers using the Global Cache auto-notify sensor inputs.
    How It Works:
    • UltraGCIRUltraGCIR uses the Global Cache discovery protocol to automatically detect the Global Cache devices installed within your home.
    • Each Global Cache device is queried for installed modules.omeSeer device is created for each detected module.
    • Using the Global Cache iLearn utility, you learn the IR commands for your remote controls and save the results to a file.
    • Using the IR Import configuration web page, you then import the learned commands for the desired IR module.
    • Learned IR commands can added, modified or deleted using the IR Devices web page.
    • Control your IR devices and relays using HomeSeer device actions.
    Features:
    • Support for an unlimited number of Global Cache devices. However, the plug-in is currently limited to a total of 90 HomeSeer devices (about 22 Global Cache GC-100-06 units).
    • Support the GC-100 and iTach Global Cache IR/Relay devices.
    • Automatically detects all Global Cache devices on your home network.
    • Ability to disconnect and reconnect a Global Cache device.
    • Error Try/Catch logic to ensure plug-in doesn't fail with an unhandled exception.
    • Web page is non-code behind ASP.Net to allow the user to customize the code and interface.
    Example Usage:
    • Control your IR device using the HomeSeer web control.
    • Control your IR device using HSTouch and HomeSeer device actions.
    • Turn off your audio/video equipment using a HomeSeer event and a HomeSeer device action trigger.
    • Mute the TV volume when your telephone rings using a HomeSeer event and a HomeSeer device action trigger.
    Installation:
    • Install and uninstall support using HomeSeer's new plug-in install template.
    Version 1.1.3993.38767 - Released Dec 08, 2010
    • First official release.
    Version 11.1.4152.35475 - Released May 15, 2011
    • Documentation added.
    • SendIrCommand() API command added.
    Version 1.1.4246.36142 - Released Aug 17, 2011
    • Fixed issues assoicated with HP Touchpad
    Version 1.1.4416.29782 - Released Feb 03, 2011
    • Add option to ignore Global Cache devices connect to the network.
    Version 1.1.4446.41323 - Released March 04, 2011
    • Added IR Export function.
    Version 1.1.4798.17631- Released Feb 19, 2013
    • Added support for the iTach WiFi CC device.
    • Modified the HomeSeer relay devices to detect when a relay command was not acknowledged by the Global Cache device.
    Version 1.1.4809.16816 - Released March 02, 2013
    • Fixed the "TriggerUIFormat" error associated with the "UltraGCIR IR Trigger". This error occurred when you saved an event without selecting a learned IR pattern.
    Version 1.1.4999.26515 - Released Sept 08, 2013
    • Added support for the Global Cache iTach Flex.
    Ultrajones
    [ ScreenShots ]
