Thanks for the quick reply! Maybe I missed something, I don't see devices being published from homeseer until I click either value or string in the publish config part of the MQTT plugin... maybe I'm missing something?
HomeSeer MQTT plugin.
Originally posted by terafin View PostThanks for the quick reply! Maybe I missed something, I don't see devices being published from homeseer until I click either value or string in the publish config part of the MQTT plugin... maybe I'm missing something?
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
MQTT IP address
I want to use node-red and the mqtt plugin to send my IP address to HomeSeer.
I've created a flow and that sends the string to the MQTT device but without
the points but the node-red debug is showing the IP address in the correct
form with the points.
In the HS3 MQTT device settings I've marked "Update string".
But the updated string shows only the numbers without the points.
Where is the issue ?
Fischi
Originally posted by Fischi View Post...
I've just looked into the HS.log. :
Info: Received MQTT topic: /Public_IP payload: xx.xxx.xxx.xx
The Log shows the IP address correctly with the points but the MQTT
device doesn't.
Only without the points.
Fischi
The IP address in HomeSeer becomes the device. You do not have to create a virtual one. Then click on the MQTT link on the HomeSeer UI. And click subscriptions you will see the TOPIC about Node-Red. So if you published Node-Red in general would be ====> Node-Red/# . Anything from then on you publish from that end will be locked in the general TOPIC>
Now add that general topic to mqtt HomeSeer devices. If it's the first time you have done this then you also to tick the MQTT box in the device type list of the HomeSeer UI. When you go back to the home page the list of mqtt devices will be there.
EDIT. You did not mention that you have already a device created and/ or not showing!
Originally posted by Eman View PostEDIT. You did not mention that you have already a device created and/ or not showing!
Eman.
I've created many devices like weather icon number, CPU temperature,
outside temperature from openweathermap ... -some with Node-Red/...
and some added manually.
Now I gave "Node-Red/IP/WANIP" to the input node and to the debug node.
HomeSeer has found the MQTT topic subscribe, I've added it and in the device I see XXXXXXXXXX instead of XX.XXX.XXX.XX . (X=my IP digits from 0-9)
Only a 10 digit number without the "."
Fischi
Fischi
Ok then,
What you have there is gone beyond mqtt plugin (removing the decimal points )
You may have to contact Geert-jan on the the plugin forum and /or search the web about such a node (or flow). If the CPU temp. shows correctly there is no reason to why it's different for the IP.
Take a look at this: http://flows.nodered.org/flow/9559f217b08913702c38 You may need to add the mqtt node to it.
NOTE: If it's the HomeSeer IP (Windows) you will have to use Jon00 Remote Computer Control & Network Monitor HS3
EmanLast edited by Eman; January 5, 2017, 03:55 PM.TinkerLand : Life's Choices,"No One Size Fits All"
Thanks Eman,
for the CPU temp there came a similar error :
It has to do with the "." !
If the CPU temp is 35.9 the HS3MQTT device showed 359. I've added a function node
and this multiplies the 35.9 by 10 ----> so it will be 359.
In the settings of the MQTT device I've set "Multiply by 0,1" (COMMA instead
of "." so I get the correct value of 35,9 .
This works for node-red values with ONE ".". or "," but the IP address
has three "decimal points" and it's not a value which I can multiply with
anything.
That's corious the plugin ignores the "."
Best regards,
Fischi
anything.
Best regards,
Fischi
Then again not so fast!
I have added it with that flow in the link above but by just adjusting only the Inject node TOPIC from ip to Node-Red/IP
TIP: It's nice to not overcrowding your Node-Red by just adding new connctions to the ones already created like the message debug node and/ or mqtt!
Originally posted by Eman View PostI have added it with that flow in the link above but by just adjusting only the Inject node TOPIC from ip to Node-Red/IP
Eman.
I think the problem might be the decimal separator.
I thought that a string may have signs like a "." without those issues
because it isn't a decimal separator in this sence .
Fischi
Hey Fischi,
I was about to ask you if those guys have to watching you
Then I found this funny topic:http://whatismyipaddress.com/ip-basics
Originally posted by Fischi View PostI've removed the topic from the mqtt-node but still missing the "."
Fischi
Mine is exactly as it should be. Connect the link to the exec node first and fire it and see what happens. And don't forget to deploy!
EmanLast edited by Eman; January 5, 2017, 05:24 PM.TinkerLand : Life's Choices,"No One Size Fits All"
Attempting to use this to control some MQTT sockets, little finicky. I have to use a work around with 2 devices to make it function as a regular device.
It'd be nice if I could have the MQTT plugin create a new virtual device that was able to be both controlled and updated by subscribing to two different topics.
So I can have a single device subscribed to /status/switch/S20_16A003/relay/0 for updates and
publish to /command/switch/S20_16A003/relay/0 to control it.
