DCM Status
    DCM Status
    Just an FYI relating to DCM Status.
    See that it comes up as not OK with a value of zero where as old HS2 Plugin showed an OK with a value of zero.
    The API shows:
    DCM TROUBLE 0000 0011 0000 1000
    DCM OK 0000 0011 0000 1001
    For status information on the old Homeseer 2 serial plugin it shows:
    Status 3 = OFF
    Value 0 = "OK"
    On current Omni plugin it shows:
    Status 0 = OFF
    Value 0 = "DCM"
    I installed plugin on second HS3 box for thermostat stuff and went to first box where it was installed and I think there I just flipped the status values to show the correct icon.
