Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > Ecobee (3P)
Ecobee (3P) Discussions related to the Ecobee plugin by Spud
Old December 9th, 2017, 03:11 PM
amattas amattas is offline
Can't Install Plugin on Linux
Whenever I install I get this error.
Date/Time Pri Type/Error Message/Source
Dec-09 2:06:38 PM Error Error, Creating plugin instance: HSPI_Ecobee.exe->Exception has been thrown by the target of an invocation.->Could not load type 'HSPI_Ecobee.EcobeeApp' from assembly 'HSPI_Ecobee, Version=3.0.0.20, Culture=neutral, PublicKeyToken=null'.
Dec-09 2:06:38 PM Updater Install/Update of package Ecobee was successful.
Dec-09 2:06:38 PM Updater Warning File exists, not overwriting: \opt\homeseer\Config\\Ecobee.ini
Dec-09 2:06:38 PM Updater Extraction Complete.
Dec-09 2:06:38 PM Updater Extracting files from zip file: images.zip
Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\System.Time.dll
Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\Ecobee.Net.dll
Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\bin\Ecobee\Newtonsoft.Json.dll
Dec-09 2:06:38 PM Updater Copying file: \opt\homeseer\HSPI_Ecobee.exe.config
Dec-09 2:06:38 PM Updater Installing package Ecobee
Dec-09 2:06:38 PM Updater Update HSPI_Ecobee.exe downloaded successfully
Dec-09 2:06:37 PM Updater Downloading update: Ecobee
Dec-09 2:06:37 PM Updater Starting download of updates
Old December 9th, 2017, 04:04 PM
Rupp's Avatar
Rupp Rupp is offline
Can you post your system profile using tools > help which may help to spot an issue. Also did you try restarting HS3 just to see if that helps?
-Rupp
Old December 9th, 2017, 04:05 PM
MESSAGE BOARD (copy/paste section below to message board posts)
Current Date/Time: 12/9/2017 3:05:08 PM
Linux version: Linux jarvis 4.13.0-16-generic #19-Ubuntu SMP Wed Oct 11 18:35:14 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux System Uptime: 0 Days 4 Hours 51 Minutes 56 Seconds
IP Address: 10.0.1.3
Number of Devices: 199
Number of Events: 11
Available Threads: 786
Enabled Plug-Ins
3.1.0.22: Sonos
3.0.1.130: Z-Wave
HELP DESK (copy/paste section below to help desk tickets & emails)
License: Registered
License: 108387
User Name and Access Level: default (Admin)
WAN IP Address: 72.49.195.167
Web Server Port: 80
Location: (Latitude) 39.341965 (Longitude) 71.03a-84.406761
Enabled Plug-Ins
3.1.0.22: Sonos
3.0.1.130: Z-Wave
Old December 9th, 2017, 05:36 PM
spud's Avatar
spud spud is offline
Moderator
Is it a SEL?
If so, this is a known that is currently being worked on by HST, see this thread: https://forums.homeseer.com/showthread.php?t=191911
Old December 9th, 2017, 06:50 PM
No, It’s my own Ubuntu server
Old December 9th, 2017, 06:55 PM
spud's Avatar
Moderator
ok, then try to install mono-complete
sudo apt-get install mono-complete
Old December 9th, 2017, 07:33 PM
Sweet, that worked! Now to config the plugin when I get home, the authorize button doesn’t seem to work with mobile safari.
Failure to install on Linux jmvetter JowiHue Plug-In 4 September 19th, 2017 10:12 PM
Fresh linux install error jonathanm70 Caddx 9 April 2nd, 2017 12:48 PM
Linux version won't install - SendFailure JasonCreager Arduino Plugin (3P) 3 April 24th, 2016 09:56 PM
Upgrading Linux Install jim@beersman.com HS3/PRO Beta Releases 12 February 15th, 2016 11:55 AM
BLStat/Linux - Install Fails PCK BLStat (3P) 1 May 15th, 2014 05:54 AM
