I am adding a couple of buttons to the default HS3Touch default_camera screen (where the pan and tilt buttons are located). They are IR ON and IR OFF buttons.
Having some problems setting up the buttons. The following is what I have done for the IR ON button. In the actions line I have selected Homerseer: Run HS Script......... In the script field I have added the following: &hs.GetURL("http://192.xxx.x.x:xxxx/CGIProxy.fcgi?cmd=openInfraLed&user=xxxxxxx&pwd=xxxxxxxx","" ,True,80). In the Script Procedure Line is "Main". This line can not be changed. The above command turns IR LEDS ON for Foscam Camera when used in browser, etc. but doesn't seem to work with button in HS3Touch Designer? Any help on this issue would be much appreciated !!!!! Rick Bonari
