Hello everybody, I'm new here and am looking forward to working with HomeSeer
I've got a client who wants a plugin for HomeSeer. I know nothing about HomeSeer and he is aware of it.
I seek your help to keep me on the right path. The second problem is that I can not VB.NET but C# I am good at. It should not be a problem,
I can probably figure it out. but if you have the choice to help me in C# I appreciate it.
The task is that I need to use the HomeSeer as a UI layer.
I need it to receive and send two languages ASCII and JSON.
It will receive commands that will then switch state of a device in the UI.
If you switch state of a device in HomeSeer, it should then send ASCII or JSON back.
I am aware that HomeSeer can receive JSON so here are some of the problem solved, I hope.
I hope you can help me to get started.
Best regards,
Johan
Best regards,
Johan
