Any ideas on how this can be done. Is there anything can make them similar to Hue functionality?
Zwave controlled RGB Lights synching with music
I suspect the ZWave network would be too slow and inconsistent for a real time application like this, from my experience. It's not a fast communication technique by a long way.
I use quite a few raspberry pis to run various home automation around the house, so a wifi/network version maybe efficient enough. Although I have been working on similar ideas in the past and still found it lacking.
Really depends on how in sync you want the lights with the music.
Originally posted by JohnneyBoy View PostI suspect the ZWave network would be too slow and inconsistent for a real time application like this, from my experience. It's not a fast communication technique by a long way.
I'm not so sure about this. I once created an event to turn a switch off if it became on and another to turn it on if it became off. The effect was a strobe. It was very fast.Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
Again this morning it took over 30 seconds for my heater plugged into a z wave appliance module to turn on. It happens randomly and is impossible to trouble shoot. I would look into DMX lighting for syncing to music.
May-10 6:06:43 AM Z-Wave Device: 1st Floor Main Heater Set to 255
May-10 6:06:09 AM Device Control Device: 1st Floor Main Heater to On (255) by/from: CAPI Control Handler
Originally posted by S-F View PostI'm not so sure about this. I once created an event to turn a switch off if it became on and another to turn it on if it became off. The effect was a strobe. It was very fast.
You'll cause the Z-Wave network to slow to a crawl and start having real issues with getting signals around attempting to send anything repetitive.
I have built a couple of ArtNet nodes from ESP01 board, a MAX485 driver and a XLR socket. For virtually nothing you can have a wireless DMX node that can be put anywhere and sends out DMX, using something free like DMXControl you can do sound to light.
I would investigate using a ZUNO for this. This gives you the Z-Wave control you require and the processing side is taken care of by a Arduino, There is a RGB dimmer example which should be readily extended to create different scenes or use a audio input to modulate the RGB unit. Just a thought, not really sure how it would all go together.
http://z-uno.z-wave.me/examples/rgb-led-strip/
