Can anyone help?
I am having trouble with the script that gets my temperature readings from my 1-wire network. everything has run flawlessly for over 2 years, until my DS9097U failed and i replaced it. The new adapter reads the temps fine (using the Dallas i-Button Viewer), but the HS script now fails! I am running vbs with HS 1.7 inw WinXP (not in .net).
I am using the using Dallas Semiconductor DS9097U COM port adapter and DS18S20 Temperature Sensors. I have loaded 1-Wire drivers version 3.2 and SDK version 4 (tm320b_32.exe).
The only difference that i can see is that the old DS9097U-S09 and new ones provided are DS9097U-009. I don't know what the difference is, or if there even is a difference.
The error that i am getting is:
8/11/2008 6:47:16 PM~!~Error~!~Script error in file: get_temps.txt: 7:Out of memory: 'CreateObject' in line 63
line 63 is...
Set access = CreateObject("owapi.OneWireAccessProvider")
in code below...
' get_temps.txt
' define public variables
Public currentTemp
Public owAddress
sub main()
' main subroutine
Call GetTemps()
end sub
sub GetTemps()
' Get temperatures and assign to virtual devices
Dim access
Dim adapter
Dim i
Dim owd_enum
Dim owd
Dim deviceState
Dim deviceName
Dim CRLF
dim set_date
' make control line feed
CRLF = Chr(13) & Chr(10)
' get the 1-Wire access provider
line 63 is...
in code below...
' get_temps.txt
Public currentTemp
Public owAddress
sub main()
' main subroutine
Call GetTemps()
end sub
sub GetTemps()
Dim access
Dim adapter
Dim i
Dim owd_enum
Dim owd
Dim deviceState
Dim deviceName
Dim CRLF
dim set_date
