SqueezeBox plugin V1.6.0 beta 3 in Updater
    Version 1.6.0 Beta 3 of the SqueezeBox plugin is available from the updater. It includes additional bug fixes and features since beta 2. Please refer to the documentation for further details. I did some testing but would like to get more feedback before making it available via the updater. This beta version requires at a minimum HS2 2.3.0.33 and SqueezeCenter 7.3.
    To install:
    • Use the HS2 Updater to install it. You will need to uninstall any existing plug-in prior to installing it using the updater. This limitation will be resolved in the final version.
    • Restart HomeSeer
    • Do not forget to update the SqueezeCenter plugin (see below)
    Bug Fixes
    • Fixed Duet volume control when used in non US locale
    • Always using LAN IP address in Duet/SB menus command
    New features
    • Supporting SqueezeCenter Extension Downloader to install the SqueezeCenter HS2 plug-in
    The SqueezeCenter plug-in is included in the HS2 Plug-in installation and stored in directory <hs2 installation="">\html\SqueezeBox. This SqueezeCenter plug-in can be installed using the SqueezeCenter Extension Downloader. HomeSeer will be the repository server for SqueezeCenter to download the plug-in:
    1. If you manually installed a prior version of this plug-in, delete the existing plug-in from the SqueezeCenter plug-in installation directory (typically C:\Program Files\SqueezeCenter\server\Plugins).
    2. Access the SqueezeCenter Extension Downloader web page (In the Settings of the SqueezeCenter web pages).
    3. Enter the URL "http://hs2_host:hs2_port/squeezebox/repo.xml" in the "additional repositories" field in the web form, replacing hs2_host with the hostname where HS2 is running and hs2_port with the port number of the HS2 web interface.</hs2_host:hs2_port>
    4. Apply and the content of the HS2 repository should appear at the end of the page. Click on check box to select the HS2 plugin and press apply to install it.
    5. Restart SqueezeCenter to enable the newly installed plug-in and configure the SqueezeCenter HS2 plug-in as in prior versions.
    </hs2>
    First chance I've had to install a beta in a while. It's up and running. I'll let you know how it performs.
    John
    Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
    Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
    HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
    Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
      Very nice!
      Now i can use the duet controller to turn on and off my devices .
      Im looking forward to the next evolution of this
      In number 3 above, i think you have omited the HS server in the url: http://squeezebox/repo.xml should probably be
      http://hs2server: port/squeezebox/repo.xml
        Originally posted by markus.bergvoll View Post
        Very nice!
        You are correct the URL should contain the hs2 server and port. I correct it. Thank you for mentioning it. It was actually in the URL in the post but since I had < and > around it, it believed they were html tags and removed the content.
          By the way, I can now use my iPhone as well, as the latest edition of ipeng now has support for 3rd party plugins in the menu.
            Attached is an updated version the Beta plug-in. The zip file only contains the plug-in DLL and should be installed after you installed the Beta version replacing hspi_squeezebox.dll with the one in the attached zip file. This version contains additional scripting APIs. My motivation to adding them sooner then I initially planned was to support playing and speaking notification messages using scripts.
            Additional APIs:
            Public Sub PlayerPlaylistMove(ByVal playerName As String, ByVal fromIndex As Integer, ByVal toIndex As Integer)
            This API moves a song within the current playlist by index.
            Public Sub PlayerPlaylistDelete(ByVal playerName As String, ByVal index As Integer)
            This API deletes a song in the current playlist by index.
            Public Sub PlayerPlaylistIndex(ByVal playerName As String, ByVal index As Integer)
            This API plays a song in the current playlist by index.
            Public Sub PlayerPlaylistSave(ByVal playerName As String, ByVal filename As String)
            This API saves the content of the current playlist into a playlist file.
            Public Sub PlayerPlaylistQueryCurrentSongTime(ByVal playerName As String)
            This API Issues a query to query the current number of seconds that the current song has been playing for the specified player. The value maybe retrieved by calling PlayerGetPlaylistCurrentSongTime.
            Public Sub PlayerPlaylistCurrentSongTime(ByVal playerName As String, ByVal time As String)
            This API enables to jump to particular position in the currently playing song for the specified player by specifying a number of seconds to seek to. You may also jump to a relative position within a song by putting an explicit "-" or "+" character before a number of second you would like to seek.
            Public Function PlayerGetPlaylistCurrentSongIndex(ByVal playerName As String) As Integer
            This API returns the index of the currently playing song within the current playlist for the specified player.
            Public Function PlayerGetPlaylistCurrentSongDuration(ByVal playerName As String) As String
            This API returns the duration in seconds of the currently playing song for the specified player.
            Public Function PlayerGetPlaylistCurrentSongTime(ByVal playerName As String) As String
            This API returns the number of seconds that the song has been playing for the specified player. To query a new value, call the API PlayerPlaylistQueryCurrentSongTime.
            Public Function PlayerGetPlaylistTrackCount(ByVal playerName As String) As Integer
            This API returns the number of tracks / songs in the current playlist for the specified player.
            Public Function PlayerGetPlayerProperty(ByVal playerName As String, ByVal prop As String) As String
            This API returns one of the following player property value specified in the prop argument: connected, power, status, mute, volume, shuffle, repeat. The values returned by this API are compatible with the ActionName argument of the APIs BroadcastActionByName and SendActionByName with the exception of the volume property which must be passed in the arg argument (and specify volume for the ActionName).
            The zip file squeezebox_announce.zip contains a HS2 VB.Net script example to play announcements. It will interrupt the currently played song if any, play the beep sound, speak a notification message and display a notification message on the player. After a delay, it will resume playing any song and restore the player to its previous state. Restoring seeking to the time where the song was interrupted will only work for mp3 files, I believe (i.e. SqueezeCenter does not support it on all formats). let us know if you come up with other variations of HS2 scripts to play or speak announcements.
            Last edited by pcp; September 14, 2009, 09:35 PM. Reason: Removing plug-in zip file since released version available in updater
              I love this plugin, But I have a few questions / requests.
              1) is there anyway to get the album art to associate with a device?
              2) is there anyway to get the track time, played and remaining into devices?
              3) is there anyway to get bit rate and from where playing into devices?
              4) can you please make the title artist device into two seperate devices title, and Artist.
              please advise if these are already possible, or will be.
              thanks a ton
              MB
                Thank you for your support and comments! About your questions:
                Reply: Suggestions are in your other related post
                Reply: Not currently with the current version of the plugin. Maybe something I can add in the next version (after 1.6) as I add HS-Touch support.
                Reply: Same answer as 2)
                Reply: If I would add more devices per player for such information, I would break the usage of some users having many players (as many as supported by the plug-in!). Is this request because you attempt to integrate it into HS-Tocuh using devices? if this is the case, the right approach is for the plug-in to directly support HS-Touch via the HS2 music APIs (planned for after 1.6).
                  I have installed the new Beta, and YES that solved alot of the requests..
                  Cant wait for HST support. if you would like a tester, please let me know
                    squeezebox_announce Example
                    PCP,
                    I just started looking at your example for annoucing messages, could you provide a few small examples of how to use the script? It's been years since I looked at vb and was hoping you might show us how to pass varables to it.
                    Thanks again...
                    -John
                      Hi Pcp,
                      Maybe i've done something wrong but there is this error in the logs ( about the squeezebox_announce ) : even if i've got a good conf ( I hope ) :
                      Sub Main(ByVal parm As Object)
                      ' ------ The following lines maybe customized to display and speak custom messages.
                      ' ------ Alternatively the script could be extended to pass them as arguments (in parm)
                      Dim PlayerName As String = "Squeezebox"
                      Dim PlayerDevice As String = "Squeezebox"
                      Dim notificationSound As String = hs.GetAppPath & "/wave_files/beep.wav"
                      Dim notificationText As String = "This is a notification message from HS2."
                      Dim notificationMessageLine1 As String = "Notification"
                      Dim notificationMessageLine2 As String = "Notification demo message"
                      Dim notificationVolume As Integer = 80
                      Dim notificationDuration As Integer = 6
                      Dim hspi As Object = hs.plugin("SqueezeBox")
                      Dim textWavFile As String = hs.GetAppPath & "/wave_files/MyNotificationText.wav"
                      Dim on_off As String
                      Dim status As String
                      Dim mute As String
                      I miss something ? Squeeze v beta 1.0.6 and v2.3.0.122 for HS2.
                      >>>>> Error here :
                        In addition to installing the 1.6 Beta using the installer, you also need to install a follow up beta update; see http://board.homeseer.com/showpost.p...01&postcount=6 (and restart HomeSeer after installation). All this will be part of the final 1.6 release in the updateer that should be available shortly.
                          Yes, i forgot to restart ... Now in logs i have this :
                          <table border="0" cellpadding="0" cellspacing="2" width="100%"><tbody><tr><td colspan="1" class="LOGDateTime1" align="left" nowrap="nowrap">12/09/2009 15:09:38 </td><td colspan="3" class="LOGType1" align="left"> SqueezeBox Script </td><td colspan="8" class="LOGEntry1" align="left">Playing notification</td></tr></tbody></table>
                          <table border="0" cellpadding="0" cellspacing="2" width="100%"><tbody><tr><td colspan="1" class="LOGDateTime0" align="left" nowrap="nowrap">12/09/2009 15:09:38 </td><td colspan="3" class="LOGType0" align="left"> SqueezeBox Script </td><td colspan="8" class="LOGEntry0" align="left">Player power: , Player status: , Player mute: , Player volume: , Player shuffle: , Player repeat: , Player playlist track count: 0 , Player playlist current song index: 0 , Player playlist current song time: , Player playlist current song duration: </td></tr></tbody></table>
                          <table border="0" cellpadding="0" cellspacing="2" width="100%"><tbody><tr><td colspan="1" class="LOGDateTime1" align="left" nowrap="nowrap">12/09/2009 15:09:47 </td><td colspan="3" class="LOGType1" align="left"> SqueezeBox Script </td><td colspan="8" class="LOGEntry1" align="left">Done</td></tr></tbody></table>
                          Without any errors ... but NO sound. Really strange, i've got the music running fine ...
                          >>>> Found the error : Lower and Uppercase in the name of the squeezebox Ok now but it's not very stable ... the message is not read every time, the music is not the same after the message, or crash ( same message as before ) randomly. If i can help, don't hesitate to ask
                            I am don't fully follow the issues. Does the script run each time? Can you determine which part of the script if run each time does not execute as expected?
