I have a few Insteon X10 devices created some time ago which update the "last change" time correctly. However, when creating new devices the last change column remains blank. Tried at least a dozen times, restarted HS3 several times in between, nothing helps. The devices switch ON/OFF correctly, it just the time stamp that is missing.
When copying a correctly behaving device the last change time shows up, but the time stamp remains as it was in the original device and doesn't update any longer.
Using latest HS3 .293 with latest Insteon .86. The correctly behaving devices were created with earlier versions of both HS3 and Insteon, but I cannot remember which.
Any suggestions?
Added info: I just tried the same device creation with HS3 .293 running Linux Mint 18. No problem there, time stamps work correctly. But I need a Jon00 plugin which is not available under Linux.
Any suggestions?
