Help with new install
Hello Paul,
I have never used a DDNS before and am setting this up to work with Geofency and running into an issue. I apologize in advance if my explanation isn't using the proper terms.
In the PHLocation plugin:
1) On the "Other" tab I have input a Listening Port: myport
2) Input User Name & Password
3) Made sure that "Allow auth bypass for IP range" is unchecked
4) Toggled http server to "Running"
Forwarded Port in router:
1) I forwarded the port number set in the plugin myport
2) Randy mentioned adding a Firewall Rule - I googled it for my Netgear router and I think they call it "Adding a custom service". I added a custom service that uses the myport port.
Decided to use a DDNS service as Randy suggested:
1) Set up host - http://myhost.mydomain.net pointing to the External IP address from the "About" screen in HS3 (IPv4)
2) Type set to DNS Host A
In Geofency App:
1) Added fence
2) In the Webhook - URL http://myhost.mydomain.net:myport/phlgeofency
3) POST Format set to Default
4) Authentication - Double checked that I had login information correct. Retyped it in both the app and in the Plugin just to make sure
When I tested the webhook it timed out. I tried from a web browser as well and received the same timed out error. When I first tested the URL I used a work computer, but in order to rule out any issues with the work internet I connected through the 4G internet on my phone.
I've obviously set something up incorrectly due to my inexperience and understanding, so your assistance would be very much appreciated!
Thank you!
Edit: Read in your User Guide to try the same URL on the same LAN to test if there is a blocked port on my router or computer, I will try this when I get home but that is the only test I haven't tried that I've read about thus far. I use a Hometroller, are there any issues there that might block a port?
Edit 2: Tried the URL while on my home LAN and still the same result. Any ideas what I haven't done correctly?
Originally posted by sooty
View Post
Hello Paul,
In Geofency App:
1) Added fence
Thank you!
