Go Back   HomeSeer Message Board > Analog & Digital IO Device Plug-ins > Analog & Digital IO Discussion > Arduino Plugin (3P)
Arduino Plugin (3P) Discussions related to the Arduion plugin for HS3 by enigmatheatre
Old December 6th, 2017, 03:56 PM
tweave tweave is offline
Seer
Working In Reverse
Hi All
I'm in the process of setting up an Arduino to control a relay board to control a number of motorise valve on my heating.
I have uploaded the Arduino Plugin and carried the instructions to set it up.
I have then linked the Relay board to the Arduino and then carried out a test but it all seam to be working in reverse every time i press the off button the relay linked to that point comes on and when I press the on button it goes off.
Also the Arduino status bar is always showing a status of "Disconnected".
Has anyone come across this and how can I correct is?
Old December 6th, 2017, 05:48 PM
enigmatheatre's Avatar
enigmatheatre enigmatheatre is online now
Super Seer
if you go to the output device config page from the device manager and click on the Arduino tab you will find an invert option that if you set it to "yes" should fix your problem.
The disconnected is strange. I would need a debug to see what is going on.
Greig.
Zwave = Z-Stick, 3xHSM100™ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts =
Various
Old January 8th, 2018, 05:46 AM
khriss75 khriss75 is offline
Seer Deluxe
Greig,
only for my curiosity: data between PC and arduino board are inverted?
In my case all works well but in my log I can see:
gen-08 10:36:28	 	Arduino Plugin	Change of Device Board:2, Output:1, Pin:10 To Value 0
gen-08 10:36:28	 	Device Control	Device: Arduino Plugin Board:2, Output:1, Pin:10 to On (1) by/from: CAPI Control Handler
So, when I put ON (1) an OUT arduino device, "0" (zero) is sent to arduino. Correct?
Old January 8th, 2018, 10:16 AM
rprade's Avatar
rprade rprade is offline
OverSeer
Quote:
Originally Posted by khriss75 View Post
Greig,
Normally the output pin on the Arduino is high when the HS device is On. When inverted, the pin is low when the HS device is On.
Randy Prade
Aurora, CO
Prades.net
"Do or do not, there is no try"
-Yoda
Old January 8th, 2018, 10:30 AM
Seer Deluxe
Quote:
Exactly my situation: output arduino pin high with HS device ON (In my case, no pin inverted). But checking the log, when I set device ON, arduino pin became High (and this is correct) but on the log i see "Arduino Plugin Change of Device Board:2, Output:1, Pin:10 To Value 0". I expect "Pin:10 To Value 1" not to Value 0.
I repeat, all works correctly is this "value 0"... As said, only a curiosity :-)
Old January 8th, 2018, 11:13 AM
rprade's Avatar
OverSeer
In Arduino speak, the pin is High at 0, Low at 1. The plug-in is handling the inversion, the inversion is not handled in the sketch. It is essentially the same as relabeling the values on the HS device. Before Greig put the inversion in the configuration, that's how we did it. The reason Greig put it in the configuration is so that the change would persist over version upgrades, where editing the HS device didn't.
HTML code is Off
Reverse triggering avpman HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 17 August 26th, 2017 10:06 AM
Reverse proxy Snelvuur HS2 / HSPRO 7 April 19th, 2013 09:51 AM
reverse led Stuart Lighting & Primary Technology Discussion 3 December 22nd, 2010 01:43 PM
reverse caller id name charlesmbell WAF NetCallerID (3P) 1 October 24th, 2010 04:54 PM
Reverse CID announcement? glt HomeSeer General Discussion Area 2 May 14th, 2005 10:14 AM
