Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > JowiHue Plug-In
JowiHue Plug-In Discussion area for JowiHue plug-in by W.Vuyk
  #21
Old January 4th, 2018, 05:28 PM
w.vuyk's Avatar
w.vuyk w.vuyk is offline
Originally Posted by HamsterHauge View Post
From log:
22:25:32.5173399 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2018-01-04T21:25:35","temperature":2509},"t":"event"} new queue size is 0 on 00212EFFFF013778
22:25:32.5192888 -- (MySensors.UpdateSensor) UpdateSensors updated Temperature 11 type ZHATemperature To 125,09
Looks like it is dividing by 100 and then adding 100? *dunk*
Wim
-- Wim
Plugins:RFXCOM, HSTouch Server, Squeezebox, BLGData, Restart, Jon00's Perfmon and Network monitor, WeatherXML, BLBackup, TenScripting, BC4, Pushover, PHLocation, JowiHue, Zwave, Sonos
650 devices ---- 336 events ----- 40 scripts
  #22
Old January 4th, 2018, 05:40 PM
w.vuyk's Avatar
Jan,
Checked the code here, but unless you are using Fahrenheit as HS setting, the value is not changed other then divided by 100. Could you test on my earlier question with the reset values button? Maybe something for the past is still acitve there?
Wim
  #23
Old January 4th, 2018, 05:44 PM
HamsterHauge HamsterHauge is offline
Hello
I did the "reset values" just after you wrote it, but no change.
I have tried to remove the sensor from deCONZ and from Jowi, and then add it again.. Still the same..
Hmmm...
  #24
Old January 4th, 2018, 05:46 PM
w.vuyk's Avatar
I am lost here.... calling it a night, hope tomorrow will bring some light
thanks,
Wim
  #25
Old January 4th, 2018, 06:01 PM
Hi Wim
A new test..
Removed the device in deCONZ and in Jowi, after that I added a Xiaomi switch, just to be sure that the sensor NOT have the same ID from dC, and after that, the sensor from before.. The sensor got the same name in dC (pressure 13), but...
Now it works! Temperature 23,27 deg..
hmm.. After 5 updates of the temperature, it's back to 100 to much..
Value 125,22
Now i'm totaly lost.
Good Night.
  #26
Old January 4th, 2018, 06:21 PM
w.vuyk's Avatar
Jan,
That still suggests that the Rest API is starting to send wrong values. Removing devices from deCONZ seems to be harder ad harder letely.
Could you create another bridge dump for me tomorrow? Change the JowiHue.ini file and enable the dump button.... send me the bridge log file.... I am guessing the value in the REST API dump is different compared from the deCONZ interface.
Wim
  #27
Old January 5th, 2018, 03:34 AM
Hi Wim
Mail posted.
Also written in the mail, about the pressure part.
22:25:22.3405846 -- (WebCommander.HandleWebQueue) Dequeue command: json {"e":"changed","id":"13","r":"sensors","state":{"lastupdated":"2018-01-04T21:25:25","pressure":983},"t":"event"} new queue size is 0 on 00212EFFFF013778
22:25:22.3425844 -- (MySensors.UpdateSensor) Unknown sensorupdate received for Pressure 13 of type ZHAPressure
  #28
Old January 5th, 2018, 08:08 AM
Hi
Aqara motion detector (PIR) works 100%, including the buildin light-sensor
/Jan
  #29
Old January 5th, 2018, 01:11 PM
Michelob Michelob is offline
Seer Plus
Hello Wim, everyone,
Same here : "aqara light and motion sensor" works perfectly. But battery level stays on 0% which is'nt true, evidently.
Aqara motion sensor (another model without light sensor) also works great. Same problem with battery level.
Temperature/humidity/pressure : helas, I only get temperature. No humidity (and we know that the pressure sensor isn't either seen in deCONZ).
Aqara press button works a lot better since this beta : now we have 4 values : press 1 time, 2 times... 4 times. Great ! about 6$ at gearbest for such a toy...
Aqara wall switch (zigbee without wires) : still ok with 3 values (left, right, both)
Aqara wall switch (wired version + zigbee) : only seen on the deCONZ map, not in the PHOSCON and thus not in Jowihue
Aqara The cube : I don't know if this is an inprovement because I didn't try before the BETA, but this is amazing. Not less than 43 status according to position or movement : swift from side 4 to 3 isn't the same as from side 5 to 3, etc. enz.... Amazing.
So, this is a huge beta Wim. Great job !
Michel
EDIT : and the Aqara door sensor works perfectly now !
  #30
Old January 5th, 2018, 02:02 PM
superwerder superwerder is offline
Originally Posted by w.vuyk View Post
I will be releasing a new beta next week, that should include the weather sensor of Xiaomi. I have some doubts on the pressure device as the info I got from you all, the pressure was 0 for all... I doubt that deCONZ puts the correct value on the REST API. We will see
Wim
Hey wim,
Any eta for the door/window sensor? (Just got mine today. )
  #31
Old January 5th, 2018, 03:39 PM
mhn mhn is offline
Hi Wim.
I have a Xiaomi with ZHATemperature og ZHAHumidity. (Round temp device)
It's really hot and humid here. 3796% Rh and 2439°C.
I tried the .xml and what Jan told me on chat. I can not get the Divisor 100 /Divisor working here.
I am on 2.0.1.7.
Regards
Morten
  #32
Old January 5th, 2018, 04:54 PM
ldplusse ldplusse is offline
Originally Posted by superwerder View Post
Hey wim,
If you install the Beta version of Jowihue then they work.
I have 3 of them and they are now working with beta.
  #33
Old January 5th, 2018, 05:41 PM
w.vuyk's Avatar
Michel
Michel,
Bit surprised to hear the battery devices are created, but I did never prepare the Aqara motion sensor, so I guess one of my goals has been achieved Creating working devices even if they are not predefined!
In common, Xiaomi is not reporting battery levels, so ignore these if a battery device is created, they will stick at 0% for ever.
And yes, the cube is a realy complex device... you will need some extra work done to have simple events for it
Wim
  #34
Old January 5th, 2018, 05:45 PM
w.vuyk's Avatar
I have great news on the pressure device, reported as not working. I forgot to add the type in the configuration. I need to update the plugin for it, but then it should work the way it should.
Also, HamsterHauge's issue wit the high temperature level is also clear now. There is an error in the plugin when you have temperature correction set in the devices property/Jowihue tab. This value is multiplied by 100, which should not be done. This will also be corrected in the next beta
Wim
  #35
Old January 5th, 2018, 05:48 PM
w.vuyk's Avatar
Originally Posted by mhn View Post
Hi Wim.
I am on 2.0.1.7.
Regards
Morten
Morten,
I am wondering why this is happening. I believe we saw earlier that the database update in your installation are not working correctly before. Send me your JowiHue.db to my private mail address? I can then check if the database was updated correctly.
Also, did you try a restart? Jan needed a full HS3 restart to see correct values?
Wim
  #36
Old January 5th, 2018, 06:02 PM
mhn mhn is offline
Hi Wim
Database send.
I only restarted the plugin. I will try to restart HS.
Regards
Morten
Edit: HS restart didn't change anything.
  #37
Old January 5th, 2018, 06:28 PM
w.vuyk's Avatar
Morten,
That is weird as the database looks ok from here. The division should just work?
Are the devices updated? (check last changed column on the device utility page.)
Wim
  #38
Old January 6th, 2018, 05:59 AM
mhn mhn is offline
Hi Wim.
Best way to answer I think. :-)
Regards
Morten
  #39
Old January 6th, 2018, 07:43 AM
erdek erdek is offline
Philips ambient light sensor values too low
strange behaviour after updating Jowihue from 2.0.1.0 to 2.0.1.6 and the beta 2.0.1.7: all luminance values of ambient lights sensor (Philips Motion Sensor) went from +20.000 to around 400, tested on 3 devices. I restored my Homeseer backup, so back to Jowihue 2.0.1.0 and all values are ok again (+20.000 during daylight). Any ideas?
  #40
Old January 6th, 2018, 07:54 AM
Sorry, false alarm, there appears to be a problem with the Homeseer update from 3.0.318 to 3.0.368, did not notice that before. HS3 3.0.318 with Jowihue plugin 2.0.1.7 beta works fine (regarding ambient light sensors at least).
HTML code is On
Beta JowiHue: adding support for RaspBee and ConBee gateway w.vuyk JowiHue Plug-In 207 February 4th, 2018 03:35 AM
Beta JowiHue: combining on/off with Bright devices w.vuyk JowiHue Plug-In 27 July 19th, 2016 07:15 AM
JowiHue Beta 1.0.6.11 (Philips Hue Bridge V2 (Homekit)) w.vuyk JowiHue Plug-In 54 January 29th, 2016 02:33 PM
JowiHue beta release 1.0.4.8 for Linux w.vuyk JowiHue Plug-In 9 November 25th, 2014 01:45 PM
JowiHue Philips Hue control beta now available w.vuyk HS3 Plug-In Development 223 September 17th, 2014 02:01 PM
