Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraRachio3 HSPI
UltraRachio3 HSPI Discussion area for the UltraRachio3 Irrigation Controller Plug-in
  #61
Old April 24th, 2018, 07:56 PM
mminehan mminehan is offline
For those of you having problems with controlling zones via the plugin (i.e. not being able to stop a zone etc) you might like to try the following. It's not perfect but an improvement on these issues.
  1. Disable the plugin from the 'manage plugins' list.
  2. Delete ALL the UltraRachio devices (zones, weather, root etc.)
  3. Go to the 'Config' folder in your HS3 directory and delete/rename the hspi_ultrarachio3.ini and hspi_ultrarachio3.ini.bak files.
  4. Enable the plugin and reconfigure (API token, units etc).
  5. Then restart HS3.
All going to plan you should now have rebuilt your UltraRachio devices. You will need to modify any events or scripts that use the UltraRachio devices.
I did this and it seems to working much better. I can now turn the zones off using the 'watering state' device. But using the 'zone control' to turn the zone off has no effect. Also if you use the app or web UI to control the zone the plugin does not change, even after waiting for the update interval set.
It's a real shame that this plugin is not working properly since Rachio update the API. It used to work perfectly. I'm very keen to help Ultra sort this out. Is it something to do with options maybe?
Mine are: units metric, update frequency 2 minutes, forecast today and tomorrow, device image yes.
I'd be interested to see what other people find after recreating the devices.
Marty.
iCore5 Win 10 Pro x64 SSD
HS3 Pro Edition 3.0.0.435 Windows
BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
  #62
Old April 27th, 2018, 10:04 AM
sgottscho sgottscho is offline
Marty.
Tried all the suggestions zones still not able to be turned off from the zone control devices. Only from the watering state device.
Current Date/Time: 4/27/2018 10:01:52 AM
HomeSeer Version: HS3 Standard Edition 3.0.0.435
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 0 Days 7 Hours 16 Minutes 39 Seconds
IP Address: 10.1.0.123
Number of Devices: 338
Number of Events: 149
Available Threads: 800
HSTouch Enabled: True
Event Threads: 0
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed: Windows Defender
Enabled Plug-Ins
1.0.3.0: BLShutdown
3.1.1.24385: Blue-Iris
2.0.22.0: BLUPS
3.0.0.46: EasyTrigger
3.0.0.33: iTunesDAAP
3.0.2.0: MeiHarmonyHub
0.0.0.38: Pushover 3P
1.0.0.7: Restart
30.0.0.36: RFXCOM
3.0.6554.33094: UltraMon3
3.0.6685.27970: UltraRachio3
3.0.0.83: weatherXML
3.0.1.190: Z-Wave
  #63
Old April 28th, 2018, 08:54 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
Event Threads: 0
Email Send Queue: 0
Enabled Plug-Ins
1.0.3.0: BLShutdown
2.0.22.0: BLUPS
1.0.0.7: Restart
30.0.0.36: RFXCOM
3.0.1.190: Z-Wave
I noticed a similar issue, but wasn't sure the zone didn't turn off because my sprinklers are still winterized. I can turn the zones off and the API response from Rachio indicates it's off, but their app still indicates it is watering. Are you able to confirm your zone is on because it is still watering or are you using the Rachio App to tell you it's still watering?
  #64
Old April 28th, 2018, 05:49 PM
I can confirm the physical zones correspond to the app/WebUI. If the WebUI indicates watering the zone is actually watering. Using the app/WebUI works as expected.
Using the plugin not so much:
change plugin 'zone control' to on -> zone starts watering and app/WebUI indicates zone is running
change plugin 'zone control' to off -> zone continues watering and app/WebUI continues to indicate zone is running
change plugin 'watering state' to stop watering -> zone stops watering and app/WebUI indicates zone off
use app/WebUI to turn a zone on -> zone starts watering but plugin remains in off/idle state -> change plugin 'watering state' to stop watering -> zone stops watering even though the plugin thinks the zone is already off
Hope this makes sense.
It seems to me there are two issues: 1) The 'zone control' device is not sending the stop watering command to Rachio, and 2) the plugin is not updating from Rachio when a zone changes, even after waiting for the API "Update Frequency" set time.
Could part of the problem be that changing the 'zone control' device to "Zone Off" changes the 'watering state' device to "Idle" but does not actually send the stop watering command to Rachio?
Also, the 'Last Watered' devices are not updating at all. Only the weather and API remaining/reset devices are updating regularly. No API Status failures by the way. It's almost like other than weather no information is coming back from Rachio.
I appreciate the effort you are putting into this. I can imagine it is a little frustrating. But anything I can do to help (debug logs, testing etc) let me know.
Marty.
  #65
Old May 16th, 2018, 09:38 AM
cd-card-biz cd-card-biz is offline
New API - Resolved Yet?
I just installed a Rachio Gen 2 controller which I want to use with my ZEE v2.
Are the issues with the new Rachio API worked out yet?
Would this be a good time to purchase and install UltraRachio3?
Thanks for any information.
  #66
Old May 18th, 2018, 10:41 AM
I am still experiencing the same issues with zone control.
  #67
Old May 20th, 2018, 10:52 PM
Seeing as there has been no fix for the zones not turning off with the individual 'zone controls' I have made a work around. Basically an event that changes 'watering state' to 'stop watering'. See attached screen shot.
This might work for others having the same problem.
Marty.
HTML code is On
RainMachine/Rachio/OpenSprinkler mulu Irrigation Discussion 1 December 30th, 2016 03:47 PM
Multiple Rachio Controllers ScottM UltraRachio3 HSPI 1 May 29th, 2016 08:26 PM
Rachio sprinkler controller chewie HomeSeer General Discussion Area 30 May 21st, 2016 10:22 AM
ISY Plug-in not communicating straydog99 ISY Plug-in Beta (3P) 15 May 4th, 2010 10:55 AM
M1 Plug In Stops Communicating mmnissan Elk M1 Plug-In 4 October 30th, 2006 07:33 AM
