I've searched and found several posts related to this but no answer. I'm using the web interface to edit events "/Events"
I have Z-Wave RGB bulbs, Zipato and Aeotec and I'd like to set the "Custom RGB" property of this using... anything from the UI really.
When editing an event I select "Control a Device" and then "Node 16 Z-Wave Custom RGB" I'm presented with a drop down box to the right. If I open up the drop down box I have the first empty entry and then many "Custom Color" entries, all identical.
There's no color picker and no way to enter my own RGB value (as hex, decimal or discrete RGB).
When I manually run the event, no matter what "Custom Color" entry I pick the color remains the same. So this appears to be broken on several levels.
I've seen questions about this for years and have never seen an answer. People appear to resort to using scripts or setting each color channel individually.
The "/deviceutility" web page displays a working color picker for the channel, sets the property on the device and the bulb's color changes.
Has anyone successfully changed the "Custom RGB" property of a color device from an event using the web interface? If so, how?
