Go Back   HomeSeer Message Board > Developer Support > Scripts & Plug-Ins:Development and Libraries > HS3 Scripting
HS3 Scripting Discussions related to the scripting under HS3.
Old April 22nd, 2018, 01:16 PM
yyz yyz is offline
Set virtual device value
Hi there,
So, if I create a virtual device who's value is either Off or On, this value must be retrieved by sending a curl message to an http server and parsing out the json response. I'm not sure of the different ways to do this status update. What I mean is, when I open Web Control\Devices or open HS3Touch, can I make the virtual device check it's status at that time or do I have to do everything by events (i.e. polling the http server)? I'm just a beginner here so any advice would be greatly appreciated.
Thanks, Chris
Old April 22nd, 2018, 03:08 PM
mrhappy mrhappy is offline
I'm sorry I don't quite catch exactly what you are trying - do you want to notify your external application of changes in a devices status? Or do you want to know if there is a different way of getting the status of a device?
Old April 22nd, 2018, 03:38 PM
yyz yyz is offline
Hi there,
Sorry I wasn't more clear. I would like to do both. I am basically controlling a light switch using a URL. I think I understand how to script the On\Off functions using events. I think my question is, if I were to turn off the lights directly from the outside source, how does the virtual device know this happened. Do I just poll it every once in a while? Is there a rule of thumb for the frequency of polling? Can I hurt the performance of the system by polling too often?
Old April 22nd, 2018, 04:04 PM
Originally Posted by yyz View Post
Hi there,
not the easiest topic to explain don't worry And just to be clear is that light switch controlled by HomeSeer and you are controlling it from something else like a web page via HomeSeer? So say you want HomeSeer to tell your external web page when it has changed?
For the most then yes your easiest method would be to periodically poll HomeSeer to check if the device has changed, whether or not there is any performance implication is a difficult one to answer because it would be dependent on your HS hardware, the stability of your HS system and all sorts of other factors. Personally I would not hammer the webserver with requests any less than once every couple of seconds, you could probably do it every second but personally I wouldn't want to. Best thing to do is just to experiment and see what happens, the HS web server is a custom design and no one really knows what is going on underneath, if you wanted to know the status of 100 lights then I wouldn't think this would be viable or sensible even if it was possible.
You could look at firing off an event when the light switch changed state to re-broadcast back to your page the new status, I imagine it would be forgiving enough not to do anything unusual if you sent back the same status as it was currently set to. The other option would be to look at the ASCII interface, this is a TCP port that you can open and new changes in devices all across the HS system can be read from this port - there are details of the commands and syntax in the help file/SDK. It's of course reliant on you being able to open the port and parse the results in your web page or whatever you are using.
Old April 22nd, 2018, 05:10 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Hi there,
If you provide a concrete example of what you want to do, it might be easier to answer your question. Is the light switch controlled directly by an IP command, or is the command going to HS, which sends instructions to the switch? If the former, how does the switch communicate with HS? How does HS communicate with the external source?
HS3 Pro Edition 3.0.0.435
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old April 22nd, 2018, 09:10 PM
yyz yyz is offline
The light switch is controlled directly by an HTTP command (ie http://192.168.1.50:3000/circuit/3/off) or from a panel. The status of the light is also done by HTTP command (ie http://192.168.1.50:3000/circuit/3 returns a JSON payload). I think there's a socket that I can subscribe to but that's something I'll do down the road. The light switch can also be controlled from the panel itself.
Old April 24th, 2018, 08:37 PM
yyz yyz is offline
Thanks for everyone's advice...
Old May 15th, 2018, 08:57 PM
fcol's Avatar
fcol fcol is offline
Have you looked into Jon00's DataScraper plugin:
https://forums.homeseer.com/showthread.php?t=175423
"Allows you to scrape data from Web pages and/or files on your network. Multiple virtual devices can be created from the data obtained with a mix of your own text/images & scraped data."*
I just installed DataScaper and am using it to poll the status of the handy OpenGarage device (garage door state, ultrasonic sensor distance, and vehicle presence). Then I just run a recurring event to periodically update the status of those virtual devices. In my case, I don't care if the state isn't synced up in real-time since the OpenGarage sensors are secondary to my primary garage door sensor.
*The above Datascraper description came from this list of all of Jon00's excellent utilities:
https://forums.homeseer.com/showthread.php?t=123313]
Old May 15th, 2018, 10:38 PM
yyz yyz is offline
Thanks much for the response. I'll take a look at the plugin.
Old May 15th, 2018, 10:41 PM
yyz yyz is offline
Bummer, it looks like the plugin is for Windows only...
Old May 16th, 2018, 12:12 AM
fcol's Avatar
Sorry - I can't script (other than copying other examples from this forum). I think I was trying to do something similar to you and spent a couple hours messing around until I found that Datascraper plugin.
To trigger your light via an http command, you could use hs.getURL in a .vb script (and trigger via an event). e.g.,
https://forums.homeseer.com/showthre...75#post1061175
I think that getting the device status and passing it onto a virtual device is trickier (for non-scripting beginners). I found this to set a device string:
https://forums.homeseer.com/showthre...28#post1153428
To scrape data from a webpage, I found some useful stuff here:
https://forums.homeseer.com/showthread.php?t=165045
https://forums.homeseer.com/showthre...7525&styleid=1
Then I (unsuccessfully) tried to learn how to use vbscript and InStr function to parse the desired values from the webpage. That's when I stumbled upon Datascraper and gave up trying to write my own script...
Old May 16th, 2018, 01:27 AM
yyz yyz is offline
Awesome, thanks for the links. I am pretty good at VB and C#. It's just a matter of finding the right examples to get me started. I appreciate you helping me out...
Old May 16th, 2018, 01:53 AM
jon00's Avatar
jon00 jon00 is offline
Not sure you read that but Datascraper works fine on both Windows & Linux versions of HS3.
Jon
Old May 16th, 2018, 02:01 AM
yyz yyz is offline
Sorry, my bad. I was looking at the wrong plugin. Thanks...
Store and retrieve device status (in virtual device?) Patholoraptor BLDenon (3P) 1 August 9th, 2016 09:25 PM
Can a virtual Harmony Hub device control a real device or activity in HS? rayvino Harmony Hub 15 April 13th, 2016 07:53 AM
Virtual device to mimic a real device? U5tabil HomeSeer Software 5 July 20th, 2015 02:09 PM
HS3 Script Syntax to copy one virtual device status string to another virtual device pjohnson HS3 Scripting 8 December 31st, 2014 02:48 PM
Parse device string and update as the value of a virtual device ccat HomeSeer General Discussion Area 5 December 14th, 2010 04:32 PM
