Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
  #21
Old April 23rd, 2018, 07:32 PM
tenholde tenholde is offline
Super Seer
I've been waiting a long time with this as an open bug, and many of your users use this plugin.
I would appreciate anything you can do.
  #22
Old April 24th, 2018, 04:35 AM
Moskus's Avatar
Moskus Moskus is offline
Seems to be running fine on both Windows and 5-6 Zee2's.
HSPro 3.0.0.435, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
  #23
Old April 24th, 2018, 05:24 PM
rloeb rloeb is offline
v435 -- Possible problemw/ Blue-Iris Plugin
Updated my Linux HS3 system (Ubuntu 16.04) to .435. Plugin manager is reporting Blue-Iris plugin as "INFO: Plugin start is pending." I don't know how else to see any other information. Suggestions? I don't seem to be getting any alerts from BI...
  #24
Old April 24th, 2018, 05:32 PM
concordseer concordseer is offline
Uninstall and reinstall it again. That might help. Check your logs and see what they are reporting when you do this.
  #25
Old April 24th, 2018, 05:37 PM
andyf andyf is offline
Just give it a few seconds then refresh the web page.
  #26
Old April 24th, 2018, 07:59 PM
Unhappy
Reinstalled. Rebooted. Waited 2 hours. BI Plugin is still "pending." HS3 events says it's not running. I use BI for motion detection, triggering HS3 events for security purposes. Going to have to drop back to v.368 :-(
Rog
  #27
Old April 24th, 2018, 08:24 PM
Unistalled BI Plugin, reinstalled, log says, "Finished initializing plug-in Blue-Iris" and Device List says it's connected, but it's not accepting JSON messages.
  #28
Old April 25th, 2018, 05:27 AM
What version of Mono is installed.
  #29
Old April 25th, 2018, 09:45 AM
Mono 5.10.1.47
  #30
Old April 25th, 2018, 09:52 AM
happnatious1's Avatar
happnatious1 happnatious1 is offline
It's not clear if you're still getting the pending plug-in message but if you are try disabling another plug-in And re-enabling it and see if it clears the blue iris plugin that work for me on a previous version.
  #31
Old April 25th, 2018, 10:19 AM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
Good point. I've seen a plug-in hang during startup before as well, and it turned out that the problem was actually a different plug-in - which may or may not produce a warning message of its own. What other plug-ins do you have? In my case it was the 'Startup' plug-in that was the culprit, but I haven't seen the problem for some time.
HS3 Pro Edition 3.0.0.435
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
  #32
Old April 25th, 2018, 10:35 AM
Still have pending message. Shutdown another plugin, shutdown BI plugin, started BI plugin, started OpenSprinkler plugin. OpenSprinkler successfully started. BI is still pending.
  #33
Old April 25th, 2018, 11:11 AM
Moskus's Avatar
Yeah, my TextSeer has the same issue. Can't really see why. And the plugin works as intended, for TextSeer it's just the status message that isn't updated properly.
  #34
Old April 25th, 2018, 12:25 PM
Have you shutdown Homeseer and rebooted your Unit.
  #35
Old April 25th, 2018, 06:31 PM
(Shutdown and reboot.) Yes, multiple times.
  #36
Old April 25th, 2018, 09:21 PM
I have determined that the BI Plugin is not even running, even though the HS3 log indicates that it initiated. Dropping back to HS3 v.368, which I know works.
  #37
Old April 26th, 2018, 08:39 AM
dmurphy dmurphy is offline
I'm running .435 for 5days+ with no apparent issues.
HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
  #38
Old April 26th, 2018, 08:44 AM
jeubanks jeubanks is offline
I've been running since released. Only oddity I've noticed is some z-wave sporadic behavior. However at this point I'm thinking that is the z-wave plugin as I'm running latest beta, or bad devices as it's only 2 that are acting very strange.
Then again I'm in "transition" to HS3 and I may have to exclude/include devices again to "clean" up the mesh.
  #39
Old April 26th, 2018, 09:02 AM
Jobee Jobee is offline
I updated to .435 from .428 yesterday. I read all the post for both (so I thought), but I did not realize the upgrade to .435 removed the negative (-) from in front of the Longitude which then caused the sunrise and sunset to be reversed. I thought I had read this was fixed in .435.
I put the negative (-) sign back in and the sunrise and sunset are back to correct.
Did I miss something in the posts? Is putting the (-) back the correct way to fix this?
Michael
HS3Pro on Win2012R2
Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, NetCAM, PHLocation, Pushover 3P, Random, UltraLighting3, weatherXML, ZigBee, Z-Wave
  #40
Old April 26th, 2018, 09:33 AM
Michael
It's my understanding that .435 fixed the longitude issue where before the negative was not accepted in the field. There was a blip between one of the versions and .435 where if you had the negative it would then get removed, and another blip that it was again removed after a HS restart. But I think it is finally fixed in .435. I have restarted HS a couple of times now and longitude stays put.
Discussions related to HS3 build 3.0.0.425 rjh HS3 / HS3PRO Discussion 335 May 9th, 2018 09:42 AM
Discussions related to HS3 build 3.0.0.368 rjh HS3 / HS3PRO Discussion 531 December 15th, 2017 11:20 PM
Discussions related to HS3 build 3.0.0.362 rjh HS3 / HS3PRO Discussion 92 September 25th, 2017 08:45 PM
Discussions related to HS3 build 3.0.0.357 rjh HS3 / HS3PRO Discussion 196 September 25th, 2017 06:27 PM
Discussions related to HS3 Build 3.0.0.313 rjh HS3 / HS3PRO Discussion 50 April 1st, 2017 08:57 AM
