Hello,
I am getting the following and no updates from my M1 ethernet interface
stale information.
Alarm Panel is working interface is not up to date.
Is there a way to reboot ethernet interface from Homeseer or is it a local process only with power removed ?
What can I do ?
HSPI UltraM1G
Status: OK
Version: 1.1.3056.34294
Plug-In House Codes Base: ]
Output: ^
Lighting: ^
Themostats: Unassigned
M1G Panel Status Connection Status: Connected
Commands In Queue: 0
Last Receive Event: 6/5/2008 9:08:02 PM
6/9/2008 6:04:46 AM UltraM1G Warning The ElkRP is connected to the Elk M1 Panel. Flushing 1 commands from the command queue.
6/9/2008 6:05:02 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:05:32 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:05:46 AM UltraM1G Warning The ElkRP is connected to the Elk M1 Panel. Flushing 1 commands from the command queue.
6/9/2008 6:06:02 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:06:32 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:06:46 AM UltraM1G Warning The ElkRP is connected to the Elk M1 Panel. Flushing 1 commands from the command queue.
6/9/2008 6:07:02 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:07:32 AM UltraM1G Warning Watchdog Timer indicates the ELKRP is connected to the panel.
6/9/2008 6:07:46 AM UltraM1G Warning The ElkRP is connected to the Elk M1 Panel. Flushing 1 commands from the command queue.
stale information.
What can I do ?
HSPI UltraM1G
Status: OK
Output: ^
Lighting: ^
