Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Rien Du Pre Plug-Ins > Caddx
Caddx This is the discussion area for the Caddx plug-in.
Old February 9th, 2016, 12:10 PM
akatar akatar is offline
Seer Plus
event doesn't always run
i have a caadx system with the rien plugin
now i noticed that the disarm not Always trigger the disarm event
example
i disarmed at 16:59 but the disarm event doesn't run (i disarmed a few hours early and thet worked.
but.. what is the reason of the behavour?
see pic
Old February 9th, 2016, 01:36 PM
Rien du Pre's Avatar
Rien du Pre Rien du Pre is offline
example
see pic
No Idea, what might cause this. I have several disarm triggers running and they never skipped a beat, for more than a year now.
Sounds like some external influence, maybe create the event from scratch again.
Rien du Pre
The Netherlands
Using:
Homeseer PRO 3.0.0.368 on MacOS - Running a Mac Mini
Plugin's:
RFXCOM, Caddx, HarmonyHub, BLShutdown, BLLogMonitor, BLRadar, BLBackup, FritzBox, Log2Text, BLLAN, PHLocation, Z-Wave
Link to the forum of my Plug-ins http://board.homeseer.com/forumdisplay.php?f=1216
Old February 9th, 2016, 02:03 PM
Seer Plus
i will create a second one and see what happens
Old February 9th, 2016, 10:28 PM
misraels's Avatar
misraels misraels is offline
My disarm does the same thing, only triggers about half the time. However, my arm event always works.
HS Install Date: Feb. 16, 2007
HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
Old February 11th, 2016, 03:32 PM
Seer Plus
here exactly the same, arm event works Always, disarm event almost never
( i have 3 disarm events and none of them works
Old February 13th, 2016, 05:24 AM
Hi guys,
I will investigate, but it's hard to trouble shoot. I use multiple disarm events running every day, and they work 100% of the time.
Old February 13th, 2016, 03:20 PM
Seer Plus
it works so rare that i use the relais of the caddx in combination with a fibaro ubs to see if the alarm is armed or disarmed
Old August 16th, 2016, 01:21 PM
Seer Plus
any idea yet?
i still have the same problems with the disarm event
the alarm is diabled in the hs3 webinterface only the event doesn't launch
(always)
Old August 18th, 2016, 04:45 AM
any idea yet?
(always)
The problem is that I have a 100% hit rate on disarm events.
Can you give me more information about your alarm type, connection and the event itself?
And in addition a debug log during the disarm of the alarm?
Old August 18th, 2016, 11:34 AM
Seer Plus
next time i disarm ther caddx and it doesn't work i will post it here
HTML code is On
Event Doesn't Run - Sometimes VirtualPanther HS3 / HS3PRO Discussion 9 March 11th, 2015 10:48 PM
event doesn't control lights, but status page does. completelyhis HS2 / HSPRO 14 July 3rd, 2007 09:43 AM
Any idea why this event doesn't work? otherd HS2 / HSPRO 2 December 7th, 2005 11:51 PM
Help? event script doesn't execute... gpnash Script & Plug-In Development 5 April 10th, 2003 03:14 PM
