PI Script?
    PI Script?
    Can anyone tell me how to get an instance of the PI for scripting?
    It use to be something like:
    Dim Sonos As Object = hs.plugin("SONOSCONTROLLER")
    But that is throwing an error "plugin not found". Any help would be appreciated.
    I am using v3.1.0.18
    -Skybolt
    This is what works for me:
    hs.PluginFunction("Sonos", RoomUDN, "PlayMusic", {"", "", Station,"","","","","","","",false,0})
      Where did you find the function list or scripting functions etc?
      The help file doesn't mention anything on scripting.
      EDIT: My bad. I see HS3 has new functions for plugins. Is there a function list or property list for this plugin?
      -Skybolt
        Its not documented. I searched through all of the Sonos forum and found the function. There are several posts on using it.
        I also use this for changing the linkgroup:
        hs.pluginfunction("Sonos", "", "SetLinkgroupZoneDestination", {linkgroupname, linkstring})
        Some things can be controlled using CapiControl and not the plugin function, like player mute, volume.
          Wow, that sucks that there is no information on this. Thanks for your reply's.
          -Skybolt
            what are you trying to do? maybe I can help. I have several scripts working with Sonos plugin.
              Thank you. It's so simple it's stupid.
              I am trying to check the volume level of a player and if it is lower then 30 set to 30.
              I had many scripts for Sonos, but since I switched to HS3 they don't work any more. I just need to figure out how to talk to the PI again. So far, not joy.
              -Skybolt
                That can be done using capi control and avoiding plugin interface. I will post the code after I get off work tonight.
                  We use the Sonos app and Alexa to operate the Sonos system. but we also have wall controllers to turn on speakers and select music stations and set the volume. But my wife's way of shutting off Sonos is turning the volume off, regardless of what room she is in. Short of getting divorced this is not going to change. So I need to set the volume when I am not using the app. Alexa doesn't return the volume level yet so I can't use that to check when nothing is working ...
                  -Skybolt
                    I tried CAPI, it returned the wrong volume level. But maybe I was using it wrong. Thank you.
                    -Skybolt
                      Try this:
                      Dim room_name as string
                      Dim vol_high as integer
                      Dim cc As HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(hs.GetDeviceRefByName("Sonos " & room_name & " Volume"), True, "Volume (value)%", False, False)
                      cc.ControlValue = vol_high
                      Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc)
                        Try this:
                        First of all, Thank you for taking the time and posting this.
                        Couple of questions:
                        What is this parameter supposed to be?
                        "Volume (value)%"
                        Also what does this do?
                        I couldn't get any of this to work though. Kept getting Object not set errors.
                        This is what I ran:
                        Dim room_name as string = "Office"
                        hs.writelog("Sonos Script",cc.ControlValue.ToString)
                        Thanks again
                        -Skybolt
                          sorry "value" is the variable to insert there, not vol_high. I lifted it from my script and didnt edit it correctly.
                          you need to add the room name in there for which room you want to control.
                          the other line is for the return value, which may or may not be needed and doesnt really do anything otherwise.
                          so to change the volume in a room office to volume 50 you would do this:
                          Dim value as integer = 50
                          cc.ControlValue = value
                            Thank you again for posting this code.
                            Again, the CC object is not getting initialized. Still getting Object not set errors. Sorry.
                            I used your post exactly.
                            -Skybolt
                              Are you adding the sub lines in there? This works for me.
                              Public Sub Main(ByVal parms As String)
                              End Sub
