Testing.
    Testing.
    When connected via IP (ISIP==1), does the serial connection (COM6) still work? I am getting feedback to HS3 via the SendToHS but nothing in the serial monitor in Arduino IDE.
      Arduino to Homeseer 3 Plugin API written by Enigma Theatre.
       V1.0.0.146
    int FromHS[5], oldvalue[5];
    boolean IsConnected = false;
    //**************Declare your variables here*******************
    void HSSetup() {
      //Add YOUR SETUP HERE;
    oldvalue[0]= -1;
    oldvalue[1]= -1;
    void HSloop() {
    if (oldvalue[0]!=FromHS[0]){
    Serial.print("FromHS[0] = ");
    Serial.println(FromHS[0]);
    oldvalue[0]=FromHS[0];
    SendToHS(1,77);
    if (oldvalue[1]!=FromHS[1]){
    Serial.print("FromHS[1] = ");
    Serial.println(FromHS[1]);
    oldvalue[1]=FromHS[1];
    SendToHS(2,88);
       V1.0.0.146
    void HSSetup() {
    oldvalue[0]= -1;
    oldvalue[1]= -1;
    void HSloop() {
    SendToHS(1,77);
    SendToHS(2,88);
    No the board will not open the serial connection as it is not required. Add the line Serial.begin(115200); to your HSSetup() Void.
    Greig.
    Scripts =
    Various
      Damn it! I always miss the easy ones.
      Thanks Greig!
