Go Back   HomeSeer Message Board > Energy Management Plug-ins > Energy Management Discussion
Old July 29th, 2017, 03:17 AM
Inshakoor Inshakoor is offline
Aeon Labs DSC11 Smart Power Strip Reads 0 Consumption
I just purchased the Aeotec by Aeon Labs DSC11 Smart Power Strip hoping to use it to read power from my Washer and Dryer to know when they stop so I could notify my wife and myself. I swear HomeSeer even sent emails showing that this power strip was perfect for this very thing. I plugged the power strip in and successfully paired it with HomeSeer. I can turn the outlets off and on but no matter what I do, the only readings it shows are 0. I ran the dryer for a full cycle and nothing. Plugged my phone in and nothing. Am I wrong that HomeSeer can read the watts and kiloWatts? Is this device even supported? Searches on the forum showed similar Aeon Labs power strips with success, but I'm not having any luck. Any suggestions are appreciated. Thanks!
System Information:
Current Date/Time: 7/29/2017 12:15:17 AM
HomeSeer Version: HS3 Pro Edition 3.0.0.318
Operating System: Microsoft Windows 10 Enterprise 2016 LTSB - Work Station
System Uptime: 0 Days 0 Hours 8 Minutes 10 Seconds
IP Address: XXX.XXX.XXX.XXX
Number of Devices: 161
Number of Events: 99
Available Threads: 400
Enabled Plug-Ins
3.0.24.19274: Blue-Iris
3.0.0.18: Ecobee
3.0.0.37: EnvisaLink
5.0.0.17: Global Cache
3.0.0.75: HSTouch Server
1.0.17205.396: MyQ
3.0.1.130: Z-Wave
Old July 29th, 2017, 03:28 AM
Looks like I figured out my own answer right after posting, of course lol. I went into the "No Status" "Aeon Labs Switch Binary" device properties and clicked on the Z-Wave tab. In there was a polling setting that was set to 0. I changed the polling time to 8 seconds to test and instantly things lit up. I'm getting readings from all devices that are plugged in. I'm still working out a good polling time and monitoring how accurate the readings are and how I can use them for my needs, but I think it should work.
Old September 10th, 2017, 09:07 PM
damiene77 damiene77 is offline
I was under the impression that the energy reporting would update automatically with a certain amount of wattage change (+/-). Can anyone confirm this to be true on the latest strips?
Thanks for the help in advance!
Old September 10th, 2017, 10:22 PM
rprade's Avatar
rprade rprade is offline
They do not require polling and I would strongly advise against it. It will add a lot of traffic and potential delays to your Z-Wave network.
There are parameters that can be set to determine the reporting. It can report periodically or on a current change of a configurable amount. Entering any value into parameter 255 will reset reporting to factory defaults. I have about 8 of these devices and none of them came configured the same as the next. Resetting them to factory defaults should get them reporting properly on current change of either 5% or 25-watts, whichever happens first. Attached is the manual, the parameters begin on page 9.
Randy Prade
Aurora, CO
Prades.net
Old March 9th, 2018, 11:39 AM
Timon's Avatar
Timon Timon is offline
I was wondering about how this came out? Were you able to get the mentoring working well enough to let you know that the machine cycles were actually finished?
John (N6BER), Joyce, Lucas (Golden Ret mix), Bella (Great Pyrenees) and Lance (GP).
HomeSeer Version: HS3 Standard 3.0.0.435
Linux version: hs3 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Mono version: 5.12.0.226
Z-NET V2 - Version 1.0.23
Number of Devices: 257
Number of Events: 320
Available Threads: 399
HSTouch Enabled: True
3.0.0.13: AirplaySpeak
3.0.0.48: EasyTrigger
3.0.1.109: PHLocation
0.0.0.42: Pushover 3P
3.0.1.190: Z-Wave
aeon labs smart powerstrip - Working! marekd1 HS3 / HS3PRO Discussion 34 November 27th, 2016 08:20 AM
Aeon/Aeotec Smart Strip! mikedr HomeSeer Z-Wave Plug-in 0 March 9th, 2016 01:53 AM
Z-Wave Power Strip DSC11-ZWUS - Working! madmax HomeSeer Z-Wave Plug-in 37 November 26th, 2015 04:36 PM
Aeon DSC11-ZWUS Smaart Strip and HS2? mterry63 HomeSeer Z-Wave Plug-in 0 January 31st, 2015 11:46 AM
DIY Smart Film by Aeon Labs TechHA General Home Automation Hardware Discussion 2 August 26th, 2014 09:50 PM
