Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old March 22nd, 2018, 09:48 PM
mulu mulu is offline
Alexa Does Not See Virtual Device
I have a virtual device Location which can have the state Home, Sleep, Away, and Vacation. I had the Alexa app on my Android scan for new devices but it doesn't see the device "Location". I also followed the instructions on https://forums.homeseer.com/showthread.php?t=186377, i.e. I set the Address and Device Type values. I already had "Voice command" enabled. How can I get Alexa to see my device?
Also I assume I would control it with "Alexa, set Location to Away" which is similar to how you control a device that can be dimmed.
Old March 23rd, 2018, 03:03 AM
mrhappy mrhappy is offline
You need to discover devices on the Alexa side - when you do this does the device appear?
With the smart home / connected home skill you will only have the option to set the devices on/off/dim/colour/lock etc - it is not that intuitive to get the list of possible status's from HS and set them. You would have to use something like 'set away location to on' instead. Using the other skills I believe you can do something like 'ask homeseer to set location to away' but I don't have particular experience with them to know.
Old March 23rd, 2018, 09:14 AM
rprade's Avatar
rprade rprade is offline
The Echo skill will not work with a virtual device having more than two states - On and Off. This also depends on the “Control Use” setting of the VS pairs. You can assign On and Off to two of the several Values, but you cannot Home, Sleep, Away or Vacation as commands. Only when the Control Use is assigned will the device be discovered.
Randy Prade
Aurora, CO
Prades.net
Old March 25th, 2018, 01:48 AM
mrhappy, I can confirm that "Alexa, tell Homeseer to set Location to Home/Sleep/Away/Vacation" works. I wish this would be easier. Btw, this requires the "HomeSeer Home Automation Skill" to be installed on Alexa (not to be confused with the "HomeSeer" skill. I have both installed and they work well side-by-side).
If it becomes bothersome I will create virtual devices 'Home', 'Sleep', 'Away' and 'Vacation' that only have on/off and then turn the appropriate virtual device on (and the others off). But I hope the Skill will improve so this is not necessary.
Alexa and Virtual Garage Door Device Tomgru HomeSeer Amazon Echo Skill 6 December 2nd, 2017 11:27 AM
Control Occupancy Virtual Device with Alexa? MEB HomeSeer Help 3 April 21st, 2017 04:42 PM
Virtual device not discovered by Alexa Rvtravlr HomeSeer Amazon Echo Skill 1 December 30th, 2016 12:48 PM
Challenging Event - Alexa and Virtual Device denisl HS3 Event Clinic 9 July 18th, 2016 08:34 PM
HS3 Script Syntax to copy one virtual device status string to another virtual device pjohnson HS3 Scripting 8 December 31st, 2014 02:48 PM
