Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer Amazon Echo Connected Home API
HomeSeer Amazon Echo Connected Home API Discussions related to the Amazon Echo native support for connected home products
Old June 7th, 2018, 02:14 AM
Timon's Avatar
Timon Timon is offline
Changed HS3 from the ZeeS2 to HS3 Standard edition and now Alexa doesn't work ** Solv
So I've moved from the ZeeS2 to a HS3Standard Edition using a database restore. Everything is working just fine and I can use HSTouch on a local direct connect.
Went online and changed my primary license from the ZeeS2's to HS3 Standard and now HSTouch works through MyHS so that's working fine.
Next went and issued a simple command to Alexa to turn on a light. She say it's OK but nothing happens on HS. Should work since it's signed into the same MyHS account.
What am I missing? Since HSTouch now works I would expect Alexa to work since it's the same database.
John (N6BER), Joyce, Lucas (Golden Ret mix), Bella (Great Pyrenees) and Lance (GP).
HomeSeer Version: HS3 Standard 3.0.0.435
Linux version: hs3 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Mono version: 5.12.0.226
Z-NET V2 - Version 1.0.23
Number of Devices: 257
Number of Events: 320
Available Threads: 399
HSTouch Enabled: True
3.0.0.13: AirplaySpeak
3.0.0.48: EasyTrigger
3.0.1.109: PHLocation
0.0.0.42: Pushover 3P
3.0.1.190: Z-Wave
Old June 8th, 2018, 03:29 AM
Timon's Avatar
I thought the MyHS could have handled the switch but it wanted me to disable and re-enable it. All is well now.
Moving from a ZeeS2 to a new Pi running standard HS3 using the Z-Wave card from the Z Timon HS3 / HS3PRO Discussion 35 June 6th, 2018 11:38 PM
Help! Lost ALL my events - Changed MDB file doesn't work! RacerChris HomeSeer General Discussion Area 26 October 17th, 2009 05:07 PM
Script changed to standard antoon SMS Connector 1 May 15th, 2009 07:59 AM
Unable to update Homeseer (Version Standard Edition 2.1.151.0) pdoty HS2 / HSPRO 3 November 25th, 2006 09:22 PM
Visual Studio 2005 Standard Edition Free from MS mloebl Plug-In Development 24 April 19th, 2006 09:40 PM
